changing fuel tank module
I have to change the fuel tank module in my 2001.5. I would like to know which way would be the best way to change it. Lift the bed off the truck or just drop the tank. I have accsess to a overhead crane at work. If i drop the tank has to be done with no truck lift. Would like to hear everybody two cents worth. Thanks in advance for your input.
I have had to drop mine several times and and have dropped it as opposed to lifting the bed. My bed has a fairly heavy toolbox and a headache rack in it that is lighted and there is not enough slack in the wires to raise it enough with out unhooking the wires so I drop the tank. It is two bolts, and a couple of quick connect fittings and couple clamps. I can do mine in about 15minutes.
Obviously the least amount of fuel possible makes it easier. I can do it myself with 6 or 7 gallons in it after that I need a jack.
I have done both mutiple times both ways are a PIA but I think i prefer dropping the tank I just try to get it as empty as possible and have a floor jack and 2 short jack stands to sit it on. it does not need to be on the ground to pull the sender out at a slight angle.
Thanks for the info. I did a little checking on the price of that module in the fuel tank. My local dealer wants 520 bucks for the part. I phoned my brother in edmonton he priced one out there and the price was 368 buck. That price was also from a dodge dealer why the big price difference. Talk about getting bent over. I phoned the local dealer and told him the price and he said that was the wrong price. I gave him the dodge part number and he was speechless. Makes a guy wonder how bad we are getting bent over when we have to get parts from a dealer. Again thanks for the info Garry
dealer's around here seem to be setting there own price on part's also.there's not much choice,when it come's to local dealer's in my area now.i ended up getting part's from a dealer in washington and it was still cheaper with the shipping cost.they also shipped it from a dealer closer to my area and i had it in 2 day's.
Try going to Vulcan Performance. They have the jeep liberty cannisters for one heck of a lot less. I think even with the drawstraw installed it was 200ish and without was 100ish. Direct drop in and complete if I recall correctly. Certainly worth a call.
I would follow BarryG's advice about Vulcan Performance. That or bring in a module in from the states if you can wait.
I believe hes talking about this:
http://www.vulcanperformance.com/Dra...w-p/jlfmds.htm
or this:
http://www.vulcanperformance.com/Dra...low-p/jlfm.htm
I dont have one so cant give specifics. They will ship USPS so shipping is cheap as well.
or this:
Why are you changing the module?
If the fuel gauge doesn't work, the sender is available for 45 bucks, and if your lines are rotten at the top, you can either get a remanned unit from Dodge for 150 bucks or a Vulcan draw straw for 49.
They are also available on Ebay cheap.....
I just paid $148 for the level sending unit at the dealer last week, I dropped the tank rather than pull the box and there is a I beam and chain block in my garage
two straps as opposed to a bunch of bolts and the wiring at the rear seemed to me to be a whole lot easier. I only had about a 1/4 tank of fuel and access to a cheap motorcycle jack. I also have used just a floor jack before by myself to drop the tank to replace a leaking return line.
