Cab clearance lights and fog lights
Old Oct 5, 2005 | 07:15 PM
ridofpwrstroke's Avatar
The kit I got from JC whitney cost me 30 bucks. Comes with the wire for the lights. I drilled two 1/8th" holes for the screws to thread, and one 1/4" hole in the middle of the two smaller holes for the wire to go through. When you take down your headliner, there are already spots that you can see where they fit. It was very easy. I did it to both trucks. Look just like the stock lights from dodge. Saves you 50 bucks through JC whitney. All you have to do is find the wire that comes on with the running lights. Pretty easy.
Old Oct 5, 2005 | 08:16 PM
bentwings's Avatar
A buddy of mine at work just got cab lites from a popular Dodge dealer in texas for $75 for his 04. template and the whole works. OEM stuff. Looks great.
bentwings
Old Oct 6, 2005 | 01:00 PM
Mcmopar's Avatar
ridofpowerstroke,
Do you have any pictures of the kit before the install?
Old Oct 6, 2005 | 07:55 PM
http://www.jcwhitney.com/autoparts/P...002879/c-10101
Go to this exact site on jc whitney. It came sealed with the five lights, the wires, and instructions. When you take your pillar off your truck, you can move the headliner down a bit. Then you will see the spots for the lights. I found the center of the hole by measuring(this is all in the inside) between both sides, took a spring loaded center punch and marked all five holes. Then I took a 1/4" drill bit and drilled five seperate holes. Go to outside of vehicle, stick wire from light through hole, center, and then punch the two holes for the light. Put in screws and that light is done. Pretty easy folks.
Also, they dont look like the lights in the picture. They look just like dodge lights. Generic photo on JC whitney.
Old Oct 6, 2005 | 10:33 PM
Dr. Evil's Avatar
I should HOPE NOT. Those lights are SINFULLY ugly...
Old Oct 7, 2005 | 09:15 AM
Cyborrg's Avatar
foglights
https://www.dodgeparts.com/product_i...oducts_id/1227
clearance lights
https://www.dodgeparts.com/product_i...oducts_id/1783
Old Oct 7, 2005 | 02:51 PM
sodbuster03's Avatar
Ugly Chicken Lights
I was wondering in anyone has a picture of their cab mods before attaching the light? Reason I'm asking is the previous owner of my truck put lights out of jcwhitney on it, and I was wondering how involved switching to factory lights would. To me these just look gawdy but I dont want to do a bunch of bondo and such just to change lights. Will post the link of the lights to see what others think of them.
Old Oct 7, 2005 | 03:50 PM
Dr. Evil's Avatar
Whats wrong with the stock lights??? They look so much better and are definitely worth the few extra $$, imo.
Old Oct 7, 2005 | 03:58 PM
Guess I should have made myself clearer. I want to go to the stock lights..Hate the ones on it now. Just wondering how close of a fit it will be to the holes allready in my cab...
Old Oct 7, 2005 | 04:04 PM
Mcmopar's Avatar
Where are you in North Carolina? I have a new light sitting in my truck??
Lrdchaos's Avatar
Are the lights for an 02 the same as the 03s or 01s??? Looking at getting some lights installed but don't want big round yellow lenses.
Old Oct 7, 2005 | 04:22 PM
Mcmopar's Avatar
My 98 has taller ones, my friends 2001 has lower profile ones, both are all plastic. You can see both types on the aforementioned Cabella's site.
Old Oct 26, 2005 | 02:45 PM
AggiePhil's Avatar
Originally Posted by BigBlue
Cab Lights, Part Number 82205120, $85. Includes wiring, template, lights, and bulbs.
Guys, be advised that this information is a bit incorrect. Dodge doesn't exactly have their **** together on the clearance light kit numbers. Basically, here's what they have:
#82205120 - Triangle shaped clearance light kit for early 2nd gen trucks; $85
#82207252 - Low-profile oval/square shaped light kit for late 2nd gen and 3rd gen trucks; $89
Basically, unless you have one of the early 2nd gen trucks, you want the 82207252 kit. Yes, the Dodge book says that the triangle lights are for 94-02 trucks. However, they didn't come from the factory with those and you don't want those. I had to take my kit back and do a swap. Here's the correct lights:
Old Oct 26, 2005 | 03:23 PM
Mcmopar's Avatar
My 1998 had those "incorrect" lights on it right from DC, I added them to the second 1998 I have. Why don't you want them? I think the "flat" ones look like .
Old Oct 26, 2005 | 04:48 PM
zukgod1's Avatar
[QUOTE=AggiePhil]Guys, be advised that this information is a bit incorrect. Dodge doesn't exactly have their **** together on the clearance light kit numbers. Basically, here's what they have:
So which one of those are supose the "Low Profile" lite?
