A/C Recharge Question
Old Jun 17, 2007 | 05:53 PM
AJMartin0321's Avatar
It's starting to get really hot down here so I turned on my a/c and it blew out "cool" air. This time of year, "cool" air isn't cutting it so I think I need to recharge the system. I have never touched the system so I am not sure of the details. In my Haynes manual, it gives me all of the steps, and the warning not to hook up to the "high side". The only thing is they never identify the high and low sides. I know I need to hook up to the low side, so is it the one that comes out and down towards you or is it the one that goes up and into the firewall? Just want to make sure before I kill myself performing such a simple procedure. Thanks in advance for the help.
Old Jun 17, 2007 | 06:55 PM
JSPulliam21's Avatar
You can not hook up to the high side unless you have a high side fitting. Most recharge kits only allow you to hook into the low side.
Old Jun 17, 2007 | 07:02 PM
scottsjeeprolet's Avatar
Does your system have R12?
When did they phase in the R134a?
If so you will need to buy one of the retro fitting kits. Or go have it professionally done.
Old Jun 17, 2007 | 07:36 PM
Fullsizeyota's Avatar
on my 99, the low side is on the passenger side, right behind the air box... but mine is a 24v motor.. yours might be different but its gotta be right there somewhere
Old Jun 17, 2007 | 08:23 PM
sjester's Avatar
on the 95 model the low side port is just to the left of the radiator cap covered by a black cap (at least on mine)
Old Jun 17, 2007 | 08:35 PM
95's should have R134a
Old Jun 17, 2007 | 08:46 PM
JDGnut's Avatar
As someone else stated is it 12 or 134??
They don't want you hooking to the high side, for saftey... If you have gauges, don't open the high side valve with the truck running.. This will let the high side pressure go to the can or charging tank.. and possibly bust the can/tank.. ( pushing 200+ psi into the can/tank.)
With my recovery machines I charge on the high side.. but never with the machine running.. I only use the low side if I can not get all of the charge in on the high side... You can charge on the low side..
I would not use the Leak sealers.. but I recommend the Dyes... (but you have to use a light to find the leaks..)
Charge by weight if you can... you'll be much happier...
Good Luck,
Bryan
Old Jun 18, 2007 | 11:11 AM
Thanks guys for all of the help. I found it next to the radiator cap where sjester said. One step closer to cold a/c.
Onemoparnut
Jun 5, 2009 08:13 PM
Little-bit
Apr 19, 2007 09:13 PM
crossy
Jul 26, 2006 07:17 PM
ozzie
Sep 29, 2004 08:50 PM
bigdogtruck
Jul 20, 2004 05:21 PM
