A/C Problem
Old Jul 29, 2011 | 07:11 PM
Red3quarter's Avatar
A/C Problem
I'm having a problem with my A/C in my 02 this summer. I've owned the truck since 2005 and the A/C has work fine untill this summer.
A/C is blowing warm. I can hear the compressor cycle every few seconds, one line under the hood gets very cold and the other gets hot. My BIL has A/C gauges and is going to come over when he isn't working and see what the pressures are.
I did stick a hose to the evaporator and washed it a few weeks ago when I noticed my A/C wasn't working right. I rinse a lot of crud out of it.
Old Jul 30, 2011 | 06:38 AM
biododge1's Avatar
is the blend door working? might be stuck letting some heat from the core mix with the ac
Old Jul 30, 2011 | 11:18 AM
rickf's Avatar
Sounds like it is low on refrigerant, It is shutting off on low pressure. You can buy kits to do it yourself but if you know some one with gauges it is better to do it that way.
Rick
Old Aug 11, 2011 | 06:27 AM
Stamey's Avatar
Put a little dye in it when you recharge so that you can look for the leak next time it gets low.
Chris
CTD23
Jun 9, 2006 09:32 PM
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
