a/c and heater control issues
Old Jun 4, 2008 | 01:45 AM
willTX's Avatar
Question a/c and heater control issues
My heating and ac only come on when the **** is turned all the way up. The three lower settings dont work. What could be the problem?
Old Jun 4, 2008 | 07:45 AM
high bid's Avatar
could be your fan switch.
Old Jun 4, 2008 | 09:22 AM
patdaly's Avatar
Check the blower motor resister, if you mean you only have fan at the high setting.
Old Jun 4, 2008 | 09:24 AM
cappykd's Avatar
Not sure if these rigs have 2 relays or not but it is most likely the low speed blower relay or the resistor/transistor for the blower. I have the same problem in another car and it's the blower transistor that's bad.
Old Jun 4, 2008 | 10:46 AM
SIXSLUG's Avatar
It' s most likely the resistor, when they go you get off and high speed. its under the heater box on the passenger floor, rectangular in shape and is held in place with two screws/bolts facing the floor. It will have an electrical connection attached to it. Its an easy replacement.
Kurt
Old Jun 4, 2008 | 12:42 PM
high bid's Avatar
Or don't worry about it....temp is supposed to be 100* again today!
Gator4
Jan 30, 2012 11:30 PM
schorb
Jan 28, 2011 11:41 AM
st.rodder2
Oct 2, 2010 11:46 PM
