Brake Problem
Brake Problem
If I am idleing in traffic like creeping up to a redlight my brake pedal gets hard to push like the master clyinder isn't working. But what does the brake booster or something like that do. Also the brake light comes on like the park brake is set. What kind of problem does this sound like???
Common problem with pre '97 trucks with vacuum assisted brakes.
What's happening is the vacuum pump can't keep up at idle with repeated brake applications.
Best course is to be aware of it, idle up if need be. If you want to get fancy plumb in a vacuum reservoir tank.
A lot of people press the pedal harder than they need to when they are stopped. This uses extra vacuum. If you're just creeping along, you shouldn't have to push the pedal very hard.
Note that the vacuum pump works somewhat opposite of a gas engine in generating vacuum. Gas engines have a bunch of vacuum at idle, when the throttle plate is closed. The vacuum pump is turning slowly, so pumps little air.
I suppose if your idle was exceedingly low, that would make a noticeable difference.
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
