Boost tube question
Old Mar 24, 2005 | 06:08 PM
MARKY MARK's Avatar
Boost tube question
When I installed my guages a couple years ago, I tapped the top of the intake horn to install my boost tube. It's getting crimped from when I do maintanence (fuel filter change, lift pump change, etc.). Now I would like to relocate it to the side of the intake horn. Would it be possible to use something to plug up the existing hole that was tapped?
Mark
Old Mar 24, 2005 | 06:12 PM
masonic-dodge's Avatar
I would think that a brass pipe thread plug will to the trick.
CRIS
Old Mar 24, 2005 | 06:35 PM
infidel's Avatar
You could also push the small tubing though some larger tubing like 1/4", keeps it from kinking.
Old Mar 24, 2005 | 08:12 PM
Mopar1973man's Avatar
Pipe plug in the tapped hole would do the trick for relocating.
There are several different places to remount the boost port...
* There is a port that replaces the manifold bolt and gives you a 1/8 NPT for hook up.
* There are pipe plugs under the manifold for hook up... Need to have adapter to make it work.
* Or the method your doing but relocate to a better spot... (drill & tap)
I'm sure there are others here that got ideas on this... I going to need it soon myself... Check the sig!
ZachMI2003
Aug 12, 2008 11:13 AM
ZachMI2003
Feb 24, 2008 05:07 PM
Ilikebikes
Dec 11, 2007 11:16 AM
Dean Snow
Sep 21, 2007 01:18 PM
goodtyms
Sep 6, 2006 09:03 AM
