Boost gauge HELP
Old Apr 18, 2006 | 11:11 PM
jabber's Avatar
Boost gauge HELP
Stupid question, I im in the process of installing a boost gauge. I have everything plumbed up, but when I ran the truck the gauge didn't work. Come to find out the gauge works on pressure not vacuum. I installed on the 1/8 fitting on the intake. Am I doing soming wrong?
Old Apr 18, 2006 | 11:18 PM
ratsun's Avatar
Do you mean it reads nothing at idle?
You wont register any boost readings with out load.
Old Apr 18, 2006 | 11:22 PM
mrschendel's Avatar
Ware did you find a fitting to plum into on the intake
jabber's Avatar
No, I put a hand held vacuum pump on it and nothing. I did this after I started it and revved it up with no boost showing on the gauge
Old Apr 18, 2006 | 11:25 PM
jabber's Avatar
I had the fitting from some other project.
Old Apr 18, 2006 | 11:33 PM
mrschendel's Avatar
So this fitting is on the charged air side by the engine
Old Apr 18, 2006 | 11:35 PM
jabber's Avatar
it is on the intake (vacuum).
Old Apr 18, 2006 | 11:37 PM
mrschendel's Avatar
So you have it between the air filter and turbo
Old Apr 18, 2006 | 11:40 PM
jabber's Avatar
No, should I?
Old Apr 18, 2006 | 11:44 PM
mrschendel's Avatar
Should be between the CAC an intake manifold. I just put a boost gauge on the weekend and I drilled and tapped the cross over. This is the part the dip stick tube is bolted to.
Old Apr 18, 2006 | 11:48 PM
jabber's Avatar
Here is a dumb question. Is boost vacuum or pressure? If it's vacuum than the gauge I have is bad and I am driving my self nuts for nothing. Just so you know you are saving my sanity. Thanks
Old Apr 18, 2006 | 11:49 PM
mrschendel's Avatar
Boost is pressure
Old Apr 18, 2006 | 11:51 PM
jabber's Avatar
Ok, than I have it installed in the wrong place. Thanks again.
Old Apr 18, 2006 | 11:55 PM
mrschendel's Avatar
No trouble at all
Old Apr 19, 2006 | 12:09 AM
jabber's Avatar
We have boost. You are the man!
