blowing but no air
Old Oct 15, 2008 | 11:06 PM
Gib241's Avatar
blowing but no air
I have a 2000 2500 4wd.
Transfer pump went out and replaced today - purring like a kitten with all the power once again.
I do not know if I did something or just happened at same time.
I have been having problems with blower motor sometimes not blowing air. I usually turn it off, drive a couple of miles, and she is working again. Normal for Dodge.
After pump repairs today, blower is working fine but no air coming out. I can hear it blowing around in the dash and some of it is is exiting through defrost vents. Resorted to same trick of turning it off and driving a couple of miles -still same problem. Tried switching between a/c an fresh air -still same problem.
I believe I have electronic controls and not vacuum but not 100% sure.
Any ideas, tricks, or advice to get air coming out vents again. I believe the damper is closed but not sure.
Thank you for your help!!
Old Oct 15, 2008 | 11:19 PM
camelracer's Avatar
If you don't have vacuum to the heater it will only blow through the defrost vents. Maybe you pulled a line loose while working on the transfer pump.
Old Oct 16, 2008 | 04:41 AM
dozer12216's Avatar
Yes, look for the hose left off or broken during IP replace.
Old Oct 16, 2008 | 09:10 AM
sheriffav8r's Avatar
Yeah, it's a vacuum line back along the firewall. Check to make sure all connections and plugs are in place, no loose tubes or holes....
Old Oct 16, 2008 | 09:14 AM
dieselfan's Avatar
i had a similar problem.
my vacuum line that runs along top the firewalll had a hole in it from rubbing against something. taped it up and a/c was back blowing through the vents.
herb
Jul 18, 2008 08:25 AM
jk6140
Oct 30, 2007 12:59 PM
roaming oregon
Jul 30, 2007 03:09 PM
code7
Aug 6, 2006 11:41 PM
