Big Brake Upgrade, In The Rear!!!!!
Old May 25, 2016 | 01:28 PM
City Rat's Avatar
Originally Posted by SIXSLUG
3rd Gen brakes on 2nd Gen trucks...easier with 01.5 and up with rear discs. Also need to go to 17" wheels or larger...
As I understand it if you are like me, my 99 runs drums in the rear. So even if I go with 17" wheels which I plan to do this mod would require some major surgery and I'd still have to contend with the parking brake issue, correct?
Originally Posted by VADSLRAM
My 99 got GMC brake cylinders and that was probably the best AND CHEAPEST upgrade I've done. Total cost was ~$25. They bolt up the same, use the same pads and drum.
Based on what I read this is my current plan, just upgrade to the GMC brake cylinders and maybe a proportioning valve and then better stopping power in the rear. If down the road I feel like doing what I think is major surgery that option would still be there. Does that make sense fellas?
Old May 26, 2016 | 04:53 AM
retgman's Avatar
Can someone explain what the pro portioning valve is for the brakes? And where it is located?
Old May 26, 2016 | 05:02 AM
City Rat's Avatar
Hey, this might help:
http://stoptech.com/technical-support/technical-white-papers/proportioning-valves
I only mentioned it as I wasn't sure how things would be setup after such a major swap. Good luck.
Old May 26, 2016 | 10:39 AM
VADSLRAM's Avatar
I still have the stock proportioning valve with no issues. They work off relative pressure anyway not fluid volume.
Old May 26, 2016 | 11:41 AM
City Rat's Avatar
Good to know, thanks. So just to be clear you did the full rear discs for rear drums swap already or did you just upgrade to the GMC 1 ton brake cylinders in the rear?
Old Jul 1, 2016 | 12:07 AM
Robert Rausch's Avatar
I put an 2001.5 rear end under my '95 and got instant rear discs and limited slip differential. Love it. One of the best things I ever did.
Old Jul 1, 2016 | 04:29 AM
City Rat's Avatar
Any issues with the parking brake when you switched over?
Old Jul 1, 2016 | 08:50 AM
It doesn't work too well. I made a link out of 1/8th inch cable to connect the two--'95 cable coming from the parking brake lever to the '01.5 coming from the backing plates but I need to shorten it a little bit.
Old Jul 20, 2016 | 09:34 PM
Dennis's Avatar
Has someone done a write up on what it takes to swap my 01 drums to 3rd gen discs? I've done the GMC swap. I'd like the 3rd gen discs all the way around now...
Old Jul 21, 2016 | 07:27 AM
VADSLRAM's Avatar
One ton cylinders.
I mis-typed pads. I meant same drum and SHOES.
Old Jul 21, 2016 | 07:29 AM
VADSLRAM's Avatar
Unless you've already changed wheels swapping to discs is expensive. I didn't think the stock wheels fit the discs and rotors in them.
1992 Renegade
Oct 11, 2014 03:29 PM
mudman78
Feb 19, 2013 01:25 PM
D.Wiggs
29
Aug 9, 2007 06:56 PM
jigdog
Nov 16, 2004 03:38 PM
cLAYH
Nov 12, 2004 04:51 PM
