battery problem
Old Sep 10, 2011 | 05:11 PM
Twodiesels's Avatar
battery problem
I had some bad corrosion on my battery post, and was in a bind to get the truck started, so i used a file on it to get the corrosion off and get a good connection. In the process of the filing, i have reduced the diameter of the post a little to much for the clamp to tighten. I have to have the wife crank it while i jiggle it around. Anyway, is there and way to rig something up so i dont neeed to do this? do they make a way to get the diameter back? Any ideas would be great.
Old Sep 10, 2011 | 05:28 PM
johnh's Avatar
cut a beer can to make a shim , don't ask me how i know it works!
Old Sep 10, 2011 | 05:30 PM
Colo_River_Ram's Avatar
With age comes the cage
Plan B,
A sheet metal screw between the post and clamp..
Old Sep 10, 2011 | 10:39 PM
Twodiesels's Avatar
Thanks fella's. I will try this tomorrow.
Old Sep 11, 2011 | 02:10 AM
wyododge's Avatar
Sheet lead will work also. Guys use it for fishing weights.
Old Sep 11, 2011 | 09:01 AM
blackimpala's Avatar
I have cut a little off the inside of where the bolt gos through so it will tighten down more.
Floyd
Old Sep 11, 2011 | 01:07 PM
patdaly's Avatar
Floyd
This is what I normally do...........
Old Sep 11, 2011 | 04:32 PM
Dr. Evil's Avatar
you can actually buy shims that fit over the posts
Old Sep 12, 2011 | 05:43 PM
Twodiesels's Avatar
where woud I find these?
Old Sep 12, 2011 | 05:54 PM
patdaly's Avatar
http://www.autozone.com/autozone/acc...er=257147_0_0_
http://shop.advanceautoparts.com/web...ci_sku=6280181
Plus many others I am sure.....
Rancher99
Apr 18, 2011 09:46 AM
jesussaves
Nov 7, 2010 06:55 AM
EdmontonCanada
Oct 10, 2008 11:37 AM
taildragger
38
Dec 19, 2006 09:49 AM
planejane
Aug 23, 2004 03:17 PM
