Which Batteries To Get?
Old Jul 27, 2008 | 05:05 AM
EverydayDiesel's Avatar
Well my batteries are leaking now so its time to replace them. Im curious which brand and size batteries you have had good luck with on these CTDs?
Old Jul 27, 2008 | 08:27 AM
high bid's Avatar
I've had good luck w/the auto zone Ultra Gold series. 3 yr free replacement if they go bad.
Old Jul 27, 2008 | 08:49 AM
exolent's Avatar
same as above
Duralast or Interstate
Old Jul 27, 2008 | 09:04 AM
06RAM2500's Avatar
You don't have to worry about the cold in TX like in MT. Running NAPA Orbital red tops
Old Jul 27, 2008 | 10:18 AM
infidel's Avatar
Spend the extra money and get gel cell or gel mat batteries.
No leaking or corrosion, they are truly maintenance free.
I like Optima but have been using the Napa Orbital recently. They seem to be just as good except that the warranty is shorter than Optima.
Old Jul 27, 2008 | 10:42 AM
dozer12216's Avatar
Wally world MAXX works good for me and affordable, with three year free replace.
Old Jul 27, 2008 | 10:43 AM
Wicked500R's Avatar
Optima Reds
Old Jul 27, 2008 | 10:52 AM
dieselpwr15's Avatar
I got the Interstate Workaholics. I have used them for about 5 months with no problems. Apparently, the ones I got are the commercial version with heavy plates that are made for a lot of vibration.
I had Napa batteries before I got the Interstates. They puked on me after a little more than a year.
Old Jul 27, 2008 | 11:24 AM
Mainemike100's Avatar
I've had good luck with Diehard Platinum, which I believe are similar technology as the optimas, just not the round design.
Old Jul 27, 2008 | 12:04 PM
those are $260 each right?
Old Jul 27, 2008 | 12:07 PM
jturuk's Avatar
IMHO if you are determined to stick with a lead acid type battery stick the the OEM's. If you go with anything else you are running the risk of acid leakage out of the battery caps causing big problems. I know this from first hand experience I wound up replacing all of my battery cables and clamps and damaged the harness located under the battery tray. I bought a set of Optima red tops and have never looked back. No more lead acid batteries for me!
John
Old Jul 27, 2008 | 12:08 PM
What is the correct group/size battery for these trucks?
Old Jul 27, 2008 | 12:09 PM
Diesel Doc's Avatar
1st choice optima yellow tops. They absolutelly last forever
2nd choice Interstate battery
Old Jul 27, 2008 | 12:44 PM
seahawkdodge's Avatar
I've been running Autocraft Platinum batteries for about 4 years.
Old Jul 27, 2008 | 12:51 PM
dbrick's Avatar
1 more vote for optimas.
