Back Window Leak?
Old Mar 6, 2011 | 08:40 PM
mstep3's Avatar
Back Window Leak?
I know this has probably been posted before, but I was wondering what a good solution is for fixing leaks in the back window.....Mine leaks water on the sides around that track that the sliding rear window is in.....Seems like it only does it when there is a really bad rain or if the wind is blowing the water up against the back of the cab, but i'd rather it not do it at all.....Is there a good solution for fixing this problem? Thanks....
Old Mar 6, 2011 | 11:38 PM
SIXSLUG's Avatar
Probably needs new seals.
Are you sure your third brake light isn't leaking?
Old Mar 7, 2011 | 12:16 PM
mstep3's Avatar
It could be the third brake light I guess....I actually put a new seal on this not too long ago....Pretty sure it's making a good seal.....
It just wants to leak water in around the ends of that plastic track on top that the sliding rear window slides on.....ever seen that happen? guess i need to pour some water on it with the hose & see where it's getting in.....
Old Mar 7, 2011 | 04:00 PM
SIXSLUG's Avatar
I have had a canopy on mine since I got it and had it off only a couple times...
My third brake light was leaking last fall but it was causing the carpet to get wet, I never noticed any leaking around the rear window.
I'm thinking seals or just poor design.
Old Mar 7, 2011 | 07:15 PM
jigdog's Avatar
new window
I had a slider stock when the truck was new. It had a cyclops leak under warranty and was fixed with a new gasket. About three years ago it started again and it wasn't the light. I had the window replaced with a solid one cause i never used the slider and its more secure this way. what i did learn from the window guys is that the metal/plastic dodge or whom ever slider seal is one time install at the factory and almost impossible to get window out and reuse the metal gasket seal. He seemed like he was telling the truth,i like my solid window alot better.
Old Mar 7, 2011 | 11:40 PM
mstep3's Avatar
when you say slider seal are you speaking about that piece of plastic that seems to pop into place at the top of the window & then the sliding rear window can slide back & forth under it...sort of like the track? cause that seems like where the water leaks in from......
Old Mar 8, 2011 | 12:10 AM
jigdog's Avatar
leak
No i am refering to the whole slider unit were it seals to the truck body.
Old Mar 12, 2011 | 11:49 PM
mstep3's Avatar
I was just curious....Where does the water wind up when it leaks in through the third brake light seal?
Old Mar 13, 2011 | 12:53 PM
SIXSLUG's Avatar
Usually appears as wet carpet on passenger side floor, front. Many believe its the heater core/evap but its the third brake light seal 9 out of 10 times.
Old Mar 13, 2011 | 03:23 PM
Hodge's Avatar
You could always take your garden hose and spray the back window first, and see if water comes in. Then, if it hasn't, try the brake light. Mine leaked at the brakelight. I ran a small bead of silicone around the cover where it meets metal, and mine has stayed dry.
Old Mar 26, 2011 | 07:30 PM
mstep3's Avatar
well, turns out it was the 3rd brake light....that's better than a leak in the window....water was just coming in on one side around the sliding glass....think i will just get a new seal for the brake light...
Old Sep 29, 2012 | 04:10 PM
Navy7797's Avatar
soild window
Jigdog; Where did you get the solid rear window for your truck ?
thanks
gordy
SORRY WRONG SECTION/FORUM
Rednecktastic
Aug 29, 2010 11:26 PM
twhman
Feb 2, 2008 10:39 AM
raven392003
Oct 29, 2007 11:39 AM
JoshPeters
Apr 3, 2005 08:13 AM
Stevenc
Nov 7, 2003 02:41 PM
