Antilock Brake Light
Old Oct 30, 2003 | 12:04 PM
Bradley's Avatar
HAs anyone had this happen? I was just driven down the road and the ABS/Brake light comes on, while not using the brakes or anything. My truck is an 03 2500, 4X4. I have never had to make a panic stop. The antilock brakes have never had to pulsate due to a emergency stop or slippery road surfaces. I have only had the truck for about a month. It has been back to the dealer but it does not show any codes in the computer nor any stored codes.???????????????????????????????????????
Old Oct 30, 2003 | 12:58 PM
pocketchange's Avatar
Re:Antilock Brake Light
The rear end has a sensor that will set it off and not give codes. I put a bearing kit in my series 80 and replaced the sensor (no more dash light). Also make sure the dope in the gear set is set a little BELOW the hole and gets changed every
30k, not with synthetics if you are heavy hauling. (Please don't flame me for this as I run NEO in everything else I drive)
Old Oct 30, 2003 | 06:23 PM
DPG's Avatar
DPG
In my '99, that sensor in the rear differential is called a speed sensor. With the sensor on the fritz, your brakes will work normally, but your ABS system is disabled. Should be covered under warranty.
DeWain
Old Oct 30, 2003 | 09:06 PM
TE-44's Avatar
I had the samething happen on my truck,went to dealer they replaced the left front wheel speed sensor.Lights only seemed to come on when it was raining.
Old Nov 2, 2003 | 01:35 PM
Bradley's Avatar
Thanks for the replies. When mine came on it was not showing any codes, and they could not find anything wrong. ???
curt234
May 31, 2015 01:59 PM
larry1951
Jun 4, 2008 05:28 AM
canadiancrawler
Jan 9, 2004 05:44 PM
msthomas
Jul 22, 2003 07:53 AM
Nuttymopar
Jul 12, 2003 01:30 AM
