Aluminium Wheels
Old Jul 11, 2003 | 08:03 PM
Buzzman's Avatar
Aluminium Wheels
Hi guys just bought a set of aluminium wheels for my truck they were comming off a 2000 Ram mine is a 98.5 after getting the drum machine in the outside for the back I tought everything was fine reading from previous talk on the forum so I bought 4 brad new Goodyear tire 265-75-16 got them mount on the rim get back home .<br><br>My problem is they fit perfect in the back but in the front it is another issue first they were rubbing on the pitarm so grind it off now the turn frely but when I turn the stering wheel they jam because the are getting caught in the tie rod end.<br><br>anyones whit a sugestion, because if not I am willing to sell them or trade them for a set that fit.<br><br>Thanks <br><br>Buzzman
Old Jul 11, 2003 | 08:22 PM
Buzzman's Avatar
Re:Aluminium Wheels
I already try the spacer that they put on the rear and it is not enought and if I go any thiker than this I won t be using the hub as a support .<br><br>Corect me if I am wrong.<br><br>Buzzman<br>
Old Jul 11, 2003 | 10:12 PM
ATEAV8GN's Avatar
Re:Aluminium Wheels
Buzz,<br><br>Been there done that. All you need to do, (this is gonna suck with tires on the rims), is put the front end on jack stands, pull the wheels and then turn the wheels from lock to lock, take note of where rubbing, then &quot;grind it till ya find it&quot;. Took me about 30 mins a side, after the gross material removal off the steering knuckle.I still get a little rubbing at full lock both ways, but I just try to make a conscience effort to not lock the steering out. <br><br>It can be done, I did it 8)
Old Jul 14, 2003 | 07:53 PM
Buzzman's Avatar
Re:Aluminium Wheels
I did it work just fine I grind the knoukle and for the rubbing at full lock I add to grind a little bit of material of the tie rod end now no more rubbing and the truck look great.<br><br>Thanks<br><br>Buzzman
Old Jul 14, 2003 | 10:25 PM
Homestead's Avatar
Re:Aluminium Wheels
To slip a little off topic, but still regarding aluminum wheels. Is there a listing or what is the backset of each years wheels. I have an 02 and have been told that the backspacing is 6.25, yet most (all I've found so far)aftermarket wheels are either 4.5 or 4.65. I was also told that wheels from an 02 2 wheel drive will fit my 4 wheels drive, they are the same wheels. True?<br><br>Thanks<br>
Old Jul 15, 2003 | 09:33 AM
turbodiesel_ram's Avatar
Re:Aluminium Wheels
What year did Dodge make a different backspacing for the wheels and why? I like the wheels like the ones found on the '02's compared to the earlier wheels. I've always been curious about this.
Old Jul 16, 2003 | 12:58 AM
Suburbanite's Avatar
Muted User
Re:Aluminium Wheels
Homestead &amp; turbodiesel_ram try this link for backspacing info:<br><br>http://dodgeram.org/tech/specs/wheel/specs.htm<br><br>Good luck.
Old Dec 2, 2003 | 05:46 AM
darrin's Avatar
Re:Aluminium Wheels
Hey Buzzman,
Did you have the factory chrome steel directional wheels on your truck originally? The reason I'm asking, is I'm curious if I can use the lugnuts from my steel directionals on the factory forged aluminum wheels? If anyone knows, please let me know.
Thanks,
Darrin
Old Dec 2, 2003 | 05:21 PM
Buzzman's Avatar
Re:Aluminium Wheels
Yes the lug nut are the same but center cap won t fit .
Buzzman
Old Jan 1, 2004 | 06:16 PM
darrin's Avatar
Now I'm having problems. I had the drums turned on the rear and all is well, but like Buzzman, the front rubs. Mine doesn't rub on the pitman arm or tie rod, but on the head of the bolt for the lower shock mount. I ground the head of the bolt down quit a bit, until it didn't rub in the driveway. When I went for a test drive, it still rubbed. As anyone else had this problem? Buzzman, what size spacers did you try?
Thanks,
Darrin
Old Jan 1, 2004 | 07:32 PM
AKDSLDOG's Avatar
Thumbs down
You guy's are scaring me with all this ""GRINDING" on the front end part's. IMO, I would find wheels to "fit properly" verses grinding metal off of the parts.
Bad idea in my mind.
Old Jan 2, 2004 | 10:46 AM
doodah's Avatar
hey, I got some 97 chrome factorys with 305r7516 discoverers with 1/4 tread I would trade you for just your stock uluminum rims, got a buddy with an 01 looking for a stock set of alum. for his truck! where you from?
Old Jan 2, 2004 | 01:31 PM
darrin's Avatar
doodah,
I already have a set of 98 chrome factory wheels. I went to the later model aluminiums because I like the looks better than the steel chrome ones. Thanks for the offer though.
Darrin
~Angry Tractor~
Mar 8, 2008 12:34 AM
Dodge Demon
Aug 6, 2007 02:00 PM
Clayten
Jun 30, 2007 11:50 AM
linetrash75
Oct 15, 2006 06:24 PM
ddestruel
Feb 9, 2005 12:08 PM
