AC Line connections q's?
Old Oct 13, 2005 | 08:26 PM
flycl65's Avatar
So it might be a dumb question but.....
I need to replace the condensor and drier(since the system has been opened for a couple of days). How do I get the wierd flange looking things apart? I figure I better ask before I break something not already broken. Every system I have ever worked on had screw together joints. Thanks in advance.
flycl65
oh yea 98 12v 3500 quad cab 4x4 auto
Last edited by flycl65; Oct 13, 2005 at 08:27 PM. Reason: forgot to add type of vehicle
Old Oct 13, 2005 | 09:17 PM
Jeremy Cusick's Avatar
Those are quick-connect couplings. You can get the tools from auto-zone to get em apart.
Old Oct 18, 2005 | 08:35 PM
timeagain's Avatar
yep! thats the way, they look like split bushings with a shoulder, the shoulder fits up into the fitting, same as with ford fule lines
Old Oct 18, 2005 | 10:36 PM
TORQUE's Avatar
System should be evacuated of all air, and vacuum leak tested at same time if it's been open, even for a few days without freon(need to bring to a/c shop). You can do without, but drier desicant will be saturated way too soon(and cause other internal corrosion problems).
Are you sure you found all the leaks? You may need a freon sniffer, to be sure you only do it once. If you're doing this and refilling by yourself, change out all o-rings that were disturbed(+/or sweating), and put a/c pag oil on them before install. Make sure you don't overfill with freon, and add a little a/c pag oil with it(some cans have oil in already with leak stop).
I don't like repairing it this way if you want to keep truck, and avoid future costlier repairs.
'pants
Apr 17, 2011 07:51 PM
miketriton
Oct 9, 2004 08:07 AM
Sidewinder
Jan 26, 2004 06:51 PM
RHC
Jul 7, 2003 06:03 PM
Commatoze
Dec 22, 2002 07:26 PM
