ABS/Brake light on fixed
Old Feb 22, 2011 | 07:26 AM
Contractor's Avatar
Just an FYI, my 96 has had those two lights on for three years. Finally did some poking around and found a vacuum line broken to the ABS "diaphragm" on the drivers fender. $ 20 at a junkyard and no more lights. BTW this is a diesel only part, I must have looked at 50 trucks before I figured that out.
cole
Old Feb 25, 2011 | 03:38 PM
totalloser's Avatar
Huh! Thanks for the info. Never heard of that before.
Old Feb 25, 2011 | 04:48 PM
patdaly's Avatar
96 and older with Vacuum booster brakes are the only ones that have that sensor.
Old Feb 28, 2011 | 01:20 PM
justme-'s Avatar
Is this the diaphragm on the inner fender near the firewall on the drivers side? I think the Cruise diaphragm is near the front on the same side- under the battery IIRC...
My state can;t fail you on inspection for lit ABS light, but they can for the hard brake light... hate this dual light system. Had the bulbs out of the dash for 3 years and counting.
Old Mar 2, 2011 | 07:20 AM
Contractor's Avatar
Yes, right next to the fuse box
Old Mar 2, 2011 | 08:03 AM
torquefan's Avatar
That part is actually the switch that turns the light on if it senses low vacuum. Kinda ironic that it would be causing the fault.
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
polaris800sp
Apr 7, 2009 10:08 AM
mr T
Feb 24, 2007 06:42 AM
