ABS and brake light on! Changed ABS sensor now..
Should also add that anytime you completely disconnect the batteries for any reason you must re-calibrate the apps (gas pedal) to the ECU. Simple process of turning key on w/o starting, slowly press the gas pedal to the floor and slowly letting it return to zero, turn off key. Do that a total of three times and your good to go.
My trucks sits for a year at a time with batteries disconnected, just started it after a year and half, cleaned it off and drive it for 45 minutes with no problems. Why do I need to do the throttle procedure????
I'm not completely sure but I think it has to do with the voltage setting from the TPS to the ECU.
So my problem kept coming back. Replaced the differential switch/combination valve and after a 1500 mile road trip towing my trailer I'm confident that was my problem. Found the new combination valve on ebay from a Dodge dealer in AZ for $135. Easy to replace, bleed the brake system the right way and good to go. Always like to finish the story/thread with a successful fix.
Joey-D
Dec 12, 2011 12:52 PM
out4elk
Nov 17, 2007 03:16 PM
mr T
Feb 24, 2007 06:42 AM
Joe Diesel
Jul 2, 2006 11:17 PM
