4wd indicator light?
Old Jun 19, 2005 | 01:52 PM
TxDiesel007's Avatar
Guys
Just one more question about the 4x4 indicator light, does it work when the actuator actually locks up the fork to the axle to connect it? Or does it work off the transfer case when you actually shift it into 4wd, my money is on the first guess... I just ordered a posi lock kit for my rig, so hopefully that will solve my truck issues..
For those of you curious as to what it is or what it does.. Here is the link... Thanks Paul!
http://www.4x4posi-lok.com/app_dodge.html
thank you fellas!
Tx
Old Jun 19, 2005 | 02:32 PM
Sidewinder's Avatar
The switch for the 4X4 light is inside the CAD unit itself. It is turned on when the collar slides over and locks the axles in. It does not work from the transfer case.
Old Jun 19, 2005 | 10:46 PM
Thank you sidewinder!...
That explains why it dont work, i think my whole vaccuum actuator is out, vaccuum to lines, yet no engaging 4wd....
Tx
Old Jun 21, 2005 | 09:05 AM
CTD NUT's Avatar
Yup, those vaccum actuators can go South from time to time. Many of them leak, but not enough to fail to activate. You can unbolt yours and test it with some shop air or a vaccum pump is even better if you have one available to you.
TxDiesel007
Dec 30, 2010 02:49 PM
jp39bfd
Feb 27, 2007 01:59 PM
waldersha
Nov 30, 2006 03:57 PM
tjohnson
Mar 17, 2005 10:03 AM
