No 4WD Indicator Light
Old Feb 23, 2007 | 06:59 AM
jp39bfd's Avatar
Unhappy No 4WD Indicator Light
Looking for some help. Went to engage 4WD and light does not come on? I jacked up the truck and check to see if the transfer case is engaging and it is, so I am assuming it must be either a bad light or transfer case indicator switch on the top of case. Is this a replacable bulb for the indicator? I'm hoping for the simple stupid thing first, before I spend $100 on a switch.
Old Feb 27, 2007 | 11:47 AM
Tazman's Avatar
jp39bfd,
How did you determine the x-fer case engaged? Did you check to confirm CAD functioning as well?
I believe a CAD malfunction will cause a no-show on the 4x4 lamp.
Old Feb 27, 2007 | 11:53 AM
CTD NUT's Avatar
Originally Posted by Tazman
jp39bfd,
That is correct....unless he has an 02.5 that has no CAD - then the switch will be at the t-case.
Old Feb 27, 2007 | 01:59 PM
Big Smoky's Avatar
Correct, no CAD. On my truck the wires for the reverse light and the 4wd light got ripped out by the driveshaft one day going down the highway. As soon as I can afford it, manual locking hubs are going on the truck! I HATE the frontend being locked all the time!! Not a good idea at all IMHO!
TxDiesel007
Dec 30, 2010 02:49 PM
waldersha
Nov 30, 2006 03:57 PM
TxDiesel007
Jun 21, 2005 09:05 AM
tjohnson
Mar 17, 2005 10:03 AM
