2001 Brake Problem
Old Oct 24, 2009 | 08:57 AM
TigerWebb30's Avatar
2001 Brake Problem
I have a 2001 3500 that just started giving me brake problems. Hopefully someone has experienced the same problem and can give me some help. The brake pedal is full sometimes but sometimes it goes nearly to the floor. It happens somewhat randomly so thats why I can't figure out whats causing it. When it goes to the floor I still have brakes but it is obviously harder to stop. The brake light and abs light are on. It has disc brakes on the front and rear. Any ideas? Thanks in advance for the help!
Old Oct 24, 2009 | 10:27 AM
nickg's Avatar
Sounds like master cyl to me, but could be ABSpump/assy.
try with engine off, and stand on brake pedal, if pedal slowly sinks to floor, I'd suspect bad MC (internal leakage past seals)
think a new MC is around 60$
Old Oct 24, 2009 | 04:46 PM
rebal's Avatar
sounds like it needs a new master cylinder
Old Oct 25, 2009 | 01:38 PM
SIXSLUG's Avatar
You've probably got the Hydra-Boost system in your truck. Could be air in the system. Check all your brake lines for a possible leak.
You also might try draining and replacing the power steering fluid.The two systems run off the PS pump. Just a few thoughts.
Kurt
Old Nov 25, 2009 | 04:08 PM
problem fixed
Draining the power steering fluid and putting new fluid in the system has fixed the problem for now. Just thought I would share that with anyone else who might experience this problem.
Old Nov 27, 2009 | 10:56 PM
sheriffav8r's Avatar
sounds like a bad ABS sensor to me and the ABS is defaulting off, which would feel funny, or cycle on and off. Check the continuity on the ABS lines (all three of them) to the front left engine compartment computer....
rattlebox01
Nov 6, 2009 12:28 PM
Mariner 250
Oct 10, 2006 03:31 PM
KOUNTERSC
Dec 25, 2004 05:41 PM
texdodge4507
May 15, 2004 10:32 PM
Holycack
Jun 27, 2003 03:26 AM
