2001 2wd front pads
Re:2001 2wd front pads
Spin them and look for warpage and or any large heat cracks. the small ones as far as i have dealt with are ok. it probably wouldnt hurt to repack the bearings while you have it apart
I have a 2001 3500 2wd and I just replaced the front wheel hub assemblies and checked the brakes while there. I believe you'll need an 18mm and a 22mm open end closed end, with a cheater to get the stubborn ones. I am under the impression that the bearings are sealed maintenance free type. ie: no grease required. Could be wrong and if I am someone please tell me before I smoke the set I just put in. Cause at 239$ per side....well you know. I had no problems or special tools needed and my 6 year helped me do the job. Good luck
Chip
14
Jun 21, 2009 03:59 AM
Bobcat698
Apr 1, 2007 10:26 PM
GCF724
Feb 19, 2007 04:32 PM
