1999 window motor help?
Old Mar 7, 2014 | 07:19 PM
steveo412's Avatar
Trouble shot it to the window motor. Is there any tricks I need to know about? Or links that will help in this? Im thinking I should tape the window to the door frame before attempting to pull motor? Thanks again.
Sent from my SPH-L710 using Tapatalk
Old Mar 9, 2014 | 07:50 AM
dsldan's Avatar
when I replaced mine I taped the window at the top of travel it sure helped, make sure to use string tape....
Old Mar 9, 2014 | 08:04 AM
steveo412's Avatar
Got it fixed yesturday . I Used 2in masking tape to tape the window in the closed position. Removed speaker and gave me plenty of room to remove the motor. Took out all window motor screws and then had to loosen the regulator just enough to give slack to slide motor out. Im not sure if all window motors are like this but I re used the old window motor screws. The new motor is not threaded so I ran the bolts about halfway into the new motor first before install. It was a breeze to install. I would say self tap those new holes with the motor out first. It sure is nice to have a operational window.
Tmello401
Aug 20, 2013 06:59 AM
Rednecktastic
Aug 29, 2010 11:26 PM
raven392003
Oct 29, 2007 11:39 AM
willy1947
Oct 2, 2006 04:16 PM
