1997 2500 tach issues
Old Oct 27, 2014 | 11:38 PM
lichen's Avatar
Okay, so let's keep this simple. The tachometer fluctuates, the CEL comes on and goes off erratically, but the engine stays running. I did a keyon check, and it says no codes, bad battery connection. Never mind the lights sometimes die, and never mind the engine died a few times. Ideas?
Old Oct 28, 2014 | 09:14 AM
patdaly's Avatar
Tach fluttering is typically either a chaffed signal wire, oil in the connector of the ESS, or loss of voltage to run the ESS.
I have never personally had a CEL come on when I had a problem with the tach.
Do you have a factory service manual?
Old Oct 28, 2014 | 10:12 AM
patdaly's Avatar
Clean and check the ground at G119 and see if that helps. Ground 119 corries the load for much of the thinks you describe.
Old Oct 28, 2014 | 05:38 PM
lichen's Avatar
I don't have a factory service manual, but I do have a Chilton's and a Haynes repair manual, of the common type available at Napa and so forth. I don't know where G119 is, but I can probably find it in the Haynes book. I'm going to clean the battery terminals and see if that helps, too. But I have been working 7 days a week for two months, and no end in sight! Need to find some time to work on the pickup.
Old Oct 28, 2014 | 08:30 PM
patdaly's Avatar
Look at the picture i put up, G119 is on the engine, just in front of the grid heaters.
Looking through the FSM, that ground connects to several of your issues, and I really can't find a common voltage supply point, so I hope it is a ground issue.
Don't waste your time with Chilton or Haynes, they are WAY too generic and skimpy to be useful past the very basics.
You can get a real FSM on CD for 35 bucks, I just print out the page I am looking at and can take it right to the truck without worrying about ruining my printed FSM.
http://www.genosgarage.com/1997-DODG.../#.VFBC9Wer-rg
If you intend to keep the truck, it is a lifesaver......
Old Oct 29, 2014 | 05:38 PM
lichen's Avatar
Awesome buddy, thank you.
Old Dec 9, 2014 | 10:22 PM
lichen's Avatar
Turns out it was the engine speed sensor (crankshaft position sensor.)
lichen
Nov 3, 2014 06:09 PM
banditman
20
Aug 10, 2014 07:20 PM
dws35
Jun 27, 2007 05:51 PM
dws35
0
Jun 24, 2007 07:03 PM
iker42
Nov 16, 2006 12:14 PM
