Lift Pump Issues - 1997 Cummins
Old Jun 24, 2007 | 07:24 PM
dws35's Avatar
My son has a 1997 Dodge Ran 2500 with 12 valve cummins engine. His truck will run for about 45 - 50 seconds if he manully pumps the plunger adjacent to the lift pump, then it dies.
He beleives the lift pump is going out. He would like to fix it in the least expensive manner, as he has listed it for sale in next weeks paper.
He has cleaned fuel tank, replaced the fuel, changed filters twice and still has the same results.
Can someone confirm that this is a lift pump problem. Also, can someone advise of the best place to get a replacement lift pump and let me know of part number and what price these normally cost.
Thanks
Sorry- I incorrectly posted this in the 24 valve forum.
Old Jun 24, 2007 | 07:33 PM
Common's Avatar
Thanks
Sounds like a lift pump, but it could be air in the fuel lines or leaky fuel lines...
The engine seems to be losing prime if it won't run...
Did you crack the injector lines to see if any fuel comes out while cranking?
Old Jun 24, 2007 | 07:35 PM
clutch1's Avatar
does it even start at all without using the hand pump?
Old Jun 24, 2007 | 07:36 PM
dws35's Avatar
Yes - He did crack the lines and if you prime it by hand, fuel does come out.
Any suggestions on locating a replacement pump.
Thx
Old Jun 24, 2007 | 07:39 PM
clutch1's Avatar
Thx
a Case dealer will have them.
Old Jun 24, 2007 | 08:00 PM
dws35's Avatar
it will not start without using the hand pump. If you use the hand pump, it will start pretty quickly, then run about 45 -50 seconds then die.
thx
Old Jun 24, 2007 | 08:59 PM
clutch1's Avatar
could be your lift pump. lever might not be functioning on the cam side
Old Jun 26, 2007 | 12:02 PM
oldschoolshovel's Avatar
had to replace my lp the spring had broke in to 4 or 5 pieces. I also have an air leak in the fuel system looks like is the fuel heater
Old Jun 26, 2007 | 07:21 PM
infidel's Avatar
Cummins has the best deal on lift pumps, about $80.
Sorry don't have a part number but it should be no problem, the same pump was used for many years in many different applications.
Old Jun 27, 2007 | 05:51 PM
ric o'shea's Avatar
Cummins lift pump # 4944710. Price is $83.64. This is the new surperceded part #.
Hope this helps.
lichen
Nov 3, 2014 06:09 PM
banditman
20
Aug 10, 2014 07:20 PM
orrin's diesel
Jan 4, 2012 08:17 AM
dws35
0
Jun 24, 2007 07:03 PM
iker42
Nov 16, 2006 12:14 PM
