1995 vs 1996
1995 vs 1996
I have been in the market for a 1996 to 1998 truck. I found a nice looking 1995 with a DTT transmission. What is the downside of the 1994 to 1995 units? Do they have the same P pumps as the 1996 to 1998 which are so reliable? Is the cab just a quiet?
It's just as reliable as the later p pumps, just not as powerful. The pump has a slightly lower output, and the injectors are smaller. But they will still produce good power. Chris Mayer's 95 was putting down 350+ hp with the small pump and injectors (and 13* timing!) If it is in good shape I'd say go for it. I don't see any reason for the cab to be any louder than the later ones.
I found a GS3K, fuel plate and a bit of timing were necessary to get the truck to make the power it should have stock. That transmission will make a HUGE difference over the stocker. Id take it!
1994 and 1995 Auto tranny trucks are 47RH units.
96+ are RE trannies.
Aftermarket is lacking so far on billet outputs on these trannies (input and intermediate are the same as the RE's) J&H out of CA was making a few from 300M (plenty stout) but other than that.... closed market.
P-Pumps are different. You'd have a 160 pump (if its stock) They make OK power. MOST have irratic and annoying tendencies right off idle. (kinda chatters... flutters.... REALLY hard to explain)
Good news is any P-Pump bolts right up... and they are easy to get ahold of (I traded a set of 370's for my 180 pump)
Other than that, they are pretty much the same.
so is everyone else who posted on this for that matter. I would jump on the smaller pump truck, and do some shopping around and you can find a decently priced 215 pump. They can all be tuned the same, just u can expect more gains out of the famous 215 pump...
Rick
