3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Gauges Install
Old May 5, 2010 | 04:38 PM
  #31
Navy7797's Avatar
mount
I just ordered a insight monitor with a pillar mount, has anybody used a pilar mount and did it work ok ? Thanks gordy
Old May 5, 2010 | 05:03 PM
  #32
mega-engr's Avatar
"California Style"
I have this style and did not like the fit at first. Because the countour of the mount had/showed gaps when placed over the stock pillar towards the windshield and handle. However, I took a heat gun to the mount and collapsed it a bit so there was preload on the two contours and the fit turned out nice.
I like the placement of the Insight, and it works well.
Old May 5, 2010 | 05:42 PM
  #33
Lil Dog's Avatar
Gauges going in tomorrow.
What wire did y'all tap for the dimmer/illumination?
Dimmer location.. Behind the light switch, orange wire with brown stripe.
Good info here..
Old May 5, 2010 | 05:45 PM
  #34
05 dodge's Avatar
For installation of pyro, boostbolt, andtrans temp.http://www.dieselmanor.com/diy/CMS3-...ugeinstall.htm
Old May 5, 2010 | 09:30 PM
  #35
Blake Clark's Avatar
Thanks Fellas
Good info, Im home and will be working on this in the morning.
The autometer pyro probe I dont like. Its seems like it would have an exhaust leak. Its just pushed into the NPT adapter and held in place with a set screw.
I wonder if I could use my Edge probe. Much better design and seems like I could splice it into the Auto meter harness.
Old May 5, 2010 | 09:38 PM
  #36
Nope...
Seems like you can alter the lenght of the wire... Crap.
Old May 6, 2010 | 12:02 PM
  #37
Lil Dog's Avatar
That doesn't sound like the right adapter for the EGT probe. My Autometer system years ago came with the compression fitting. That sounds like a pipe adapter for the exhaust system, not the manifold. If you are into the Swagelok fittings for instrumentation, you can just pick up a fitting and drill it out to accept the pyro.
The thermocouple should be the same for both systems, not much variety there.
Old May 6, 2010 | 09:16 PM
  #38
Its designed to be used for either the pipe setup or the NPT setup. It worked well with no leaks so Ill leave it for now.
Gauges are in!
Everything went well, bout 3 hours of work. Here are some pics, they are not the best, was in a hurry.
They are a spot on match for the factory though. They look great! Even the illumination is colored perfect.
The only (slight) issue I have is that the illumination is too bright. I wired it to the wire mentioned, also checked that it dimmed with the roller switch, and they do, but only about half as much as the dash. I wonder if there is something, like a resistor, that could be wired to decrease the illumination voltage and dim it down a bit.
Another thing I noticed is that the boost needle is a bit shaky. When it starts to peak at top boost it looks like its vibrating in place. Any ideas???
Old May 6, 2010 | 10:14 PM
  #39
mega-engr's Avatar
"California Style"
Very cool and inspiring Blake!
Old May 6, 2010 | 10:43 PM
  #40
Lil Dog's Avatar
Very nice Blake! Look very sharp.
As far as illumination, its the LED lighting that does that. There is a harness with a variable resistor pot you can get from Autometer to help with it. My EV2s pulse if I go too low on the dash dial and go out. I need the same type of device, but I might just leave it.. It wasn't too bad overhead, but might be more in your face on the pillar.
The boost is electronic or analog?
Old May 7, 2010 | 05:54 AM
  #41
Thanks Fellas
LD,
Yes, duh... a potentiometer, (or rheostat) as we in the welding world call them, geez, how could I forget about those...
The boost gauge is analog (mechanical).
Old May 7, 2010 | 06:01 AM
  #42
Just ordered me one...
Dimmer that is
Thanks!
Old May 7, 2010 | 07:09 AM
  #43
roger.t's Avatar
"DTR's Wormiest Member"
looks good Blake.
Old May 7, 2010 | 02:22 PM
  #44
2171CTD's Avatar
Looks good Blake.
Old May 7, 2010 | 03:21 PM
  #45
mega-engr's Avatar
"California Style"
How did you pick the order to place the gauges in?
