Yet another transmission 4wd problem
Old Dec 17, 2008 | 12:06 PM
Greg Mueller's Avatar
Will not go into 4wd
After a 5 speed trans and two 6 speed trans and 3 transfer cases I'm ready to buy a Ford.
I read the threads about the red and black "hoses" which look more like 12 gauge wire. Neither of them have any vacuum that I can detect. I pulled the 4 hose rubber connection off the top of the transfer case and cannot detect vacuum there.
Where does the friggin vacuum come from?
The one time a year I need 4wd and it pukes on me. I'll never buy another Dodge product.
What *** is wrong with mechanical linkage. How about a lever that engages the front end.
Old Dec 17, 2008 | 02:09 PM
Vacuum pump was disconnected.
Probably from when I had the pump replaced,last summer
Old Dec 17, 2008 | 04:20 PM
patdaly's Avatar
They have one, it is called a Posilock 4X4.
I will never, ever go back to Vacuum...........
Old Dec 18, 2008 | 06:53 AM
Redliner's Avatar
At the cowl there is a plastic vaccum line running side to side. there is a T in it right over your fuel filter area. A rubber line runs down into a plastic gray or white line. This feeds the Tcase. Check your lines and make sure none are cracked or flaking.
gscoker
Oct 13, 2011 06:22 AM
Mpieh
Sep 21, 2010 09:05 AM
Silverjay
Oct 16, 2005 08:28 AM
Silverjay
Oct 12, 2005 07:59 PM
