Wont Start!!!!
Old Jun 7, 2008 | 08:27 PM
willTX's Avatar
Thumbs down Wont Start!!!!
Ok so my rig has finally bit the dust. We've just gotten back from the lake and i get in my truck to move it and "CLICK" no start, so i try agian "CLICK" no start, what is the deal? If the starter is dead then wouldnt it click numerous times or would it just be the single "CLICK"? PLEASE HELP!!!!
Old Jun 7, 2008 | 09:05 PM
BigIron70's Avatar
Cummins Guru
I would clean and tighten battery connections first, remember grounds off first and on last. Try putting head lights on are they bright? What voltage do you have? Try starting if headlights stay bright and starter just clicks, bad starter. If headlights dim, bad battery. Sometimes I can get engine started if you tap starter with hammer while someone tries to start, if starter is going out. Good luck
Old Jun 8, 2008 | 09:55 AM
DieselLady's Avatar
If you are just getting a click and nothing happens, it is bad starter contacts. This is a common problem and you can just replace the contacts. Don't replace the whole starter as they are usually still fine. PM me and I will set you up with a contact kit. This is about 1/5 the cost of a new starter and very simple to do.
Old Jun 8, 2008 | 10:22 PM
brianpgriset's Avatar
This is probably the problem. Have you had any problems with the starter staying on either? That is another tell-tale sign of bad starter contacts. In fact I have the same problem as you right now, I got new contacts and a plunger coming in the mail for $40 shipped . NAPA wanted $220 for a new starter....
Do a search and you'll find alot of info, including a rebuild thread and a place to buy contacts.
Old Jun 8, 2008 | 11:30 PM
DieselLady's Avatar
www.sutherlanddiesel.com for starter contacts. This kit is a little more than others but you get the spring, gasket and also new insulators and nuts in case you round one off when you take it apart. I have seen cracked insulators before to. A very complete kit. FYI.
rustydeeretech
Jun 16, 2010 09:41 AM
CoolumConst
Oct 11, 2008 10:00 PM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
Desert Diesel
Dec 5, 2002 08:53 PM
