wont start
Old Apr 2, 2008 | 09:36 PM
btown647's Avatar
Unhappy wont start
probly a noob question but the fuel gauge dont work and was stupid and ran it out. so i put more in it with the thanks of a home depot guy (thanks AL ) and it still wont start the fuel pressure is slow to start up but then after i try again it goes over 15. im at a loss please help. its being fed by fass system
Old Apr 2, 2008 | 09:59 PM
Boilermaker08's Avatar
Did you bleed the air out of your lines?
If you didn't... crack a couple injector lines, crank the engine over and bleed the air out of the system.
Old Apr 3, 2008 | 12:38 AM
chainzaw's Avatar
You may also want to bump your starter a few times ( turn the key on and bumper the starter for a 1/4 second, that will turn your fass on for about 30 seconds.) As soon as the pump shuts off bump the start again and repeat several times. You may have a lot of air in the lines and fuel filter canister.
Old Apr 3, 2008 | 12:58 AM
99globalwarmer's Avatar
loosen the lines to the head 1,3,5 until fuel comes out, then tighten and go 2,4,6 that should atleast give 3 cylinders of fire to help the other 3 along.
Old Apr 3, 2008 | 12:43 PM
btown647's Avatar
bled the air out and it runs haleluha
rustydeeretech
Jun 16, 2010 09:41 AM
CoolumConst
Oct 11, 2008 10:00 PM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
Desert Diesel
Dec 5, 2002 08:53 PM
