Will a VP-44 off an HO engine fit/work on an SO engine?
i'm needing a new pump and just wondering if it would work, but if thats the case i might just go with an SO. but would i get more torqe with the HO? would my truck be an HO or an SO? was the HO only offered in the 01.5 and later?
ho's - 245 so's - 235.
if you want more power, get a programmer/box/injectors. just put a so pump on it.
i do also believe the ho's are around 17:1 and i think the so's are 16:1.... not sure though
anyways, point is, dont put a ho pump on a so! now people do put so pumps on ho's for the performance increase. the so pumps have bigger plungers and can push more fuel.
i am, of course, talking about a modded engine.
but if your going to stay stock, and put a ho pump on a so, it IN THEORY should run better. because the ho pump injects fuel at a higher pressure than the so pump, and with the stock so injectors, should make more horsepower. Doug (jetpilot) back when he owned performancedieselwarehouse.com told me that if i switched my ho pump for dads so pump that my previously dyno'd 530 hp HO truck would run much better, and his stock SO truck would run better also. but the ho pump has smaller plungers, which at the upper end of the hp ratings cannot move enough fuel to get a truck much over 500 hp. whereas a so pump is capable of 700+.
take it for what its worth, but i wouldnt put a ho pump on the so truck
i have a hypertech maxenergy, but i think i might get rid of it. i dont have any plans for the near future to built my truck up too much, maybe intake, exhaust, programer. so i guess i'll just keep looking for an SO pump. thanks for all the great input and wisdom
you say "keep looking for a so pump" like your trying to find a used one? i hope this is not the case, because a used vp has a very high chance of being just like the one you have now. check out midwest diesel or olee poole or performance diesel warehouse. ho's and so pumps are the same price. can find them for 1050 usually.
fade94
Apr 26, 2010 05:59 PM
CTD2001
Jun 3, 2008 07:50 PM
halerazor
Jan 4, 2005 11:32 AM
Evildiesel
Jun 29, 2004 11:09 PM
Oct 2, 2003 09:06 PM
