white smoke & not reving
Old Nov 1, 2004 | 06:19 PM
stackboy's Avatar
i got a newer truck 2 months ago its the 2001 24V automatic. its a great truck but right off the bat i noticed when i start the truck in the morning or if it has sat for 2 hours or more it will sit and white smoke like crazy. it also wont rev up or take off very fast. white smoke is caused by not enough fuel i heard and i talked to ppl they said i need a new lift pump. so i put on a new lift pump and bigger banjo bolts to help it out well it didnt fix anything. after it runs for 10 min the truck will take off like nothing is wrong but it will white smoke if i sit there and rev it up and keep into it. WHAT IS WRONG WITH IT thanks
Old Nov 1, 2004 | 06:55 PM
Scubasteve's Avatar
Sounds like your getting air into the system some how. You need to check your lines to make sure there are no leaks at all, wash them down and then check them.
If the lift pump has been bad for awile you could of toasted your inj pump and its just on its last legs.
Pull the codes and post back with your results.
cycling the key ON OFF ON OFF ON then reading the codes on the odometer.
Jason
Old Nov 1, 2004 | 09:51 PM
ramtd02's Avatar
that sounds like what my truck was doing about a month ago....sorry too say...you will need a new VP44 (injector pump). SORRY
Old Nov 2, 2004 | 10:05 AM
stackboy's Avatar
i had my buddy run it for codes one day and he came up with high boost and timing advanced thanks for the reply guys
Old Nov 3, 2004 | 01:35 PM
stackboy's Avatar
i checked the codes i got P1693 DTC detected in PCM, P0216 Timing failure, P0234 turbo boost limit exceeded and also PPC4, Pecu but dont know those 2. for the timing failure can i just take it in and get it adjusted or do i need a whole new injection pump
Old Nov 3, 2004 | 02:26 PM
BigBlue's Avatar
Sorry but that's the kiss of death code. You need a new injection pump. Time to upgrade to a race pump.
Old Nov 5, 2004 | 09:40 AM
stackboy's Avatar
how much is a race pump and where should i get it
Old Nov 5, 2004 | 11:38 AM
BigBlue's Avatar
I think Piers Diesel Research carries them and they cost I think a couple hundred more than a factory VP44. They also come with a one year warranty. Do a search for Hi-Flo VP44 and you should turn up some stuff.
600 Megawatts
67
Jul 25, 2018 10:42 AM
kyle_truck_pull
Sep 20, 2009 01:02 AM
SOOT4BRAINS
Dec 11, 2008 01:42 PM
ahopper
16
Oct 10, 2008 03:13 AM
scsulfri
Oct 17, 2005 02:26 PM
