Wheel bearings
Old Jun 24, 2007 | 01:14 PM
haloman's Avatar
Wheel bearings
I have a slight pull to the right and a passenger can feel a clicking in the floor board so I assume my wheel bearing is going out. I've called some of the local auto parts stores and they do not have them in stock and cannot order them. Please dont tell me I have to go to the dealer. Or is there something else it could be? I want to replace them anyways cuz at 203,xxx I am sure it needs it.
TIA
Old Jun 24, 2007 | 07:28 PM
badme's Avatar
Take the bearings and seals out and get the numbers off of them, have the parts store cross reference them. Just make sure you are careful taking them out in case you have to reuse them.
Old Jun 24, 2007 | 09:01 PM
Tocapet's Avatar
On some models, you have to replace the whole front hub, bearings & all. Costs over $200 each. I think '99 was the last year with replaceable ft wheel bearings. Fords & Chevys are the same.
Old Jun 24, 2007 | 09:03 PM
badme's Avatar
Is this truck a 4x4 or 4x2? 4x4 are available aftermarket from carquest, napa, ect as a hub asembly. 4x2 are not available and you will have to match numbers like I said before.
Old Jun 24, 2007 | 11:02 PM
haloman's Avatar
Thank you you guys for the info. That kinda sucks they arent availible for my 2wd. I'll see what I can do about matching them up.
Old Jun 25, 2007 | 08:24 AM
johnh's Avatar
good luck on getting them apart. good luck on finding new bearings w/ the preload spacer with out buying the whole assy.....
Old Jun 25, 2007 | 09:23 AM
haloman's Avatar
Is this on a 2wd? Geez on my 1st gen it was just a bearing shoved on a spindle, is this not the case here?
Mutt68
Sep 25, 2012 12:51 PM
Wilbur01
Aug 3, 2009 11:16 PM
johnh
Oct 20, 2003 05:33 PM
jdeereboy
Apr 28, 2003 09:33 AM
Tigerfan
Apr 19, 2003 08:13 AM
