whats my gear ratio ?
Old Jul 29, 2004 | 01:54 PM
01redram's Avatar
Question whats my gear ratio ?
just purchased a 01 2500 4x4 5-spd.anyone know how to determine my rear gear ratio.
Old Jul 29, 2004 | 02:08 PM
RustyJC's Avatar
Well, with a 3500 (shorter tires) and 6 speed (5th in a NV4500 and 6th in a NV5600 are very similar), if RPM's at 70 MPH are around 2000, you have 3.54 gears. If RPM's at 70 MPH are around 2350, you have 4.10 gears.
I also believe my truck's axle ratio is listed on a tag inside the glovebox door.
Rusty
Old Jul 29, 2004 | 03:23 PM
jrs_dodge_diesel's Avatar
Rusty
Yes, the axle ratio is on the sticker inside the glovebox door. I found mine there. There should also be a metal tag on the rear diff itself with the ratio stamped on it.
Old Jul 29, 2004 | 03:35 PM
dieselminded's Avatar
Tire size will change your gear ratio also. its like for every inch above stock add .10 example: 4:10 stock tires 31" = 4:50 with 35" tires ....I just learnt that on TRUCKS TV today never thought I'd get to use it.
Old Jul 29, 2004 | 03:42 PM
Mcmopar's Avatar
I don't know it's yoour truck not mine!!
Old Jul 29, 2004 | 09:54 PM
zulusafari's Avatar
I thought it was the other way around. When I look up tire calculators, they show that my effective gear ratio goes down (numerically) when I add taller tires. So the 35's get me 3.70 for my original 4.10's. Any one else know??
Old Jul 29, 2004 | 10:02 PM
01redram's Avatar
thanks for the help!checked my glove box and there it was. 454`s.i wont be pulling any supper heavy loads so these will do just fine.
Old Jul 29, 2004 | 10:03 PM
01redram's Avatar
oops! meant 354`s
Old Jul 30, 2004 | 05:33 AM
amartinson's Avatar
That's the right way.
Old Jul 30, 2004 | 07:42 AM
Mcmopar's Avatar
You can pull with the 3.54:1 ratio, I towed a boat and trailer como that weighed 17,500lbs, and I believe Haulin' in Dixie hauls a lot more and if I recal he has 3.54's.
design
32
Jun 23, 2003 10:07 PM
mbw
Mar 5, 2003 05:38 AM
Garz
Feb 3, 2003 09:08 AM
Cutthroat
Jan 8, 2003 09:37 AM
accordionjohn
Oct 7, 2002 12:54 PM
