What is this miss????
Old Jan 26, 2006 | 11:30 PM
Captain57's Avatar
What is this miss??? Truck started to miss the other day like it had water was not getting fuel. This only happens right after I start it and then it clears up after a few minutes and runs normal. Does not matter if the engine is hot or cold. Also I get no water in fuel light. I did a apps reset and had no problem for two days and then I did the code thing with the ignition key and it came up with a P1693 code and then the miss started again, same thing! Did the apps reset again and will see what happens tomorrow. Oh I changed the fuel filter before the first apps reset and no change. Anyone have any ideas, LP or?? What is a P1693 code? After it displayed the code it went blank and then said r--done? What gives????
Old Jan 27, 2006 | 10:07 AM
gitchyboy's Avatar
My truck did the same intermittently, I found that my lift pump was running intermittently and I had a leak around the fuel filter seal, I replaced the on-engine lift pump with the in tank pump and installed a FP gauge.
I am not sure if mine was an air problem or a FP problem but it is fixed.
Old Jan 27, 2006 | 01:09 PM
blackdiesel's Avatar
Registered
p1693 done , then wait a little bit and it should tell another code wait till the milage comes back up before you turn it off
Old Jan 27, 2006 | 10:53 PM
Captain57's Avatar
Thanks for the replys guys. I'll have to try to reseat the filter cap to make sure that there is no air leak. When I get home I'll do the pump at the tank and fp gauge. I had the scan done at AutoZone and it came up p0216. It says The PCM has determined that there is a discrepancy between the "actual" and the "desired" injector timing. I'll have to figure out what that means and then how do I fix it!
Old Jan 27, 2006 | 11:08 PM
Registered
bad news that's your injector pump (vp44) one grand and 5 hours and you will be back on the road sorry to tell you that .
Old Jan 27, 2006 | 11:57 PM
Captain57's Avatar
Well that's disgusting if its the vp44!!
Mar 25, 2003 05:39 AM
MnTom
Feb 27, 2003 08:13 PM
red_rattler
Feb 21, 2003 05:26 PM
Bluedresser
Jan 28, 2003 09:21 AM
gitchesum
Oct 28, 2002 01:15 PM
