What happens when you overpower the stock slushbox?
I'd really like to have an auto, but the price for upgrading is pretty hefty. About how much power increase (hp/torque) can an 00' auto take over stock? What happens if you go past that ammount, do the tranny puke, or does it just start slipping? I'm really interested in knowning, thanks.
Re:What happens when you overpower the stock slushbox?
The autos are pretty tough if you treat them carefully. I got over 200,000 miles on mine before it started to puke.<br><br>If you keep the revs up, don't let it slip when towing in OD, and don't slip it with too much go pedal off the line, I think that you should last a long time with care. After all, it is not the power, but the abuse of the power that wrecks the tranny.<br>PS...boost the line pressure a bit.<br>george
Well, it might be hard not to get on the go pedal
<br>I went for a ride in Merrick's truck down here in Laredo. He's been helping me alot, great guy. His truck is just.. fast. ****. Every single vehicle I've owned has been standard, and it's starting to get old. I guess I shouldn't have driven my mom's truck.. **** auto spoiled me. I would like to take it down to the track every now and then, wanted to pick up a PE Comp Drag, and put a single stack. I haven't bought the truck yet, I'm still debating wether or not to go slushbox or stick. The more I think about it, the more I want auto.. I've been told about 60hp over stock will kill an auto tranny, but didn't specify what "kill" is. Maybe someone will take an 01 Ford Ranger in exchange for a bomb-proof slushbox
HOW DO YOU BOOST THE LINE PRESSURE MENTIONED BY GEORGE. I'M ALSO NOT QUITE READY TO BOMB-PROOF<br>THE TRANNY DUE TO EXPENSE. QUESTION IS...WHEN BAD <br>SLIPPAGE OCCURS...IS IT NORMALLY A BAND OR CLUTCHES <br>THAT IS THE WEAK POINT THAT GIVES UP AND IS THERE<br>A GOOD BREAK-DOWN AVAILABLE ON SITE FOR RE-BUILD.<br>YEARS A GO 1969 I A 727 APART REPLACING REAR BAND.<br>THAT WORKED OUT GOOD. IT LASTED A LONG TIME AFTERWARDS. SO IF WE GET ONE SLIPPING CAN WE GET BY <br>REPLACING THE BANDS AND CLEANING IT UP??? ANY AND ALL<br>INFO WOULD BE APPRECIATED. WAYNE
Normally, it is the torque converter that lets go first. It is barely adequate for stock power. I had a comp on mine and started slipping it after running it on 3x3. You can run the comp on 1x3 or even 2x3 and be fine. If you don't tow heavily. The tranny wont puke it's guts. Only the TC will start slipping.
[quote author=John_Rodriguez link=board=4;threadid=11299;start=0#107739 date=1045934133]<br>I'd really like to have an auto, but the price for upgrading is pretty hefty. About how much power increase (hp/torque) can an 00' auto take over stock? What happens if you go past that ammount, do the tranny puke, or does it just start slipping? I'm really interested in knowning, thanks.<br>[/quote]<br><br>The answer is you can't put any more then stock power through the stock tranny without risking the tranny. I had a 2000 automatic 3500 4x4. If you bomb and don't upgrade the auto to match you are going to spend some big $$$ to fix it.
WHEN YOU KILL THE FACTORY TC DOES IT TRASH THE TRANSMISSION WITH RAW MATERIAL DAMAGING THE <br>BUSHINGS, DRUMS ETC.??? QUESTION IS WILL IT CAUSE<br>A MAJOR OVERHAUL?? WAYNE [undecided]
Well I did not upgrade my tranny before I bombed the engine. <br>The TC was thrash and the rest of the tranny needed more than a bit of attention. I think that the whole tranny should be overhauled. <br>If you have some small troubles now and mount a better TC and bomb you will put much more torque into the tranny. <br><br>AlpineRAM
Mine is being beefed up this week, I have had no problems with it. It is expensive whether you drive it in to a shop or have it towed in (more expensive towed in). The question is do you want to make the appointment on your own time or break down @ 11pm on a saturday night 150 miles from nowhere and be on a waiting list because the trans shop is backed up with work 3 weeks.<br>I agonized over dishing out the money too but decided if I wanted my truck to do what I modified it for this was a must.<br>According to Scott@ Massdiesel (he is doing my trans) typically the TC's start slipping first. I was just @ his shop yesterday for a wrench day and he's got piles of broken tranny parts of all kinds.<br>Tim
BUCKEYE4X4
Aug 28, 2007 08:32 PM
XLR8R
Nov 12, 2006 01:13 AM
gsdog1
Aug 3, 2004 12:25 PM
PADZZ
Nov 20, 2002 11:17 PM
