What could it be ???
Old Sep 15, 2010 | 11:04 PM
shaft's Avatar
Everytime I take off from a dead stop, I feel some driveline vibration. This only happens during the first 2 seconds and once the truck gets rolling the vibration disappears. What could be causing this issue? I'd like to fix this before this gets worst. Please advise, I'm all ears. Thank you.
Old Sep 16, 2010 | 01:18 AM
DIESELWRKS's Avatar
what have you checked? also the vibration you said you feel it. where do you feel it. steering wheel, butt, floor board on feet.
when my rear u-joint and yoke went out I felt it in the but and steering wheel. front shaft on my truck I felt it steering wheel and some on the floor board. bearings that I have had gone out where quiet at first then they were noisy all the time but felt no vib, I would think a out of balance tire or bad tire would give you a feeling at higher speeds than lower. check you u-joints. if you have a carrier bearing on the rear shaft see how much play you have. well I hope that helps some.
Old Sep 16, 2010 | 07:27 AM
shaft's Avatar
I apologize for not being more specific. I feel the vibration coming from the rear of the truck. I guess I kinda feel it on my butt too. It can't be the tires since it only happens the first 2 seconds. No vibration at high speeds or at the steering wheel.
I have not checked anything since I don't really know where start and I'd thought I'd ask the experts first. Thx.
Old Sep 18, 2010 | 01:10 PM
KATOOM's Avatar
Give your u-joints and your carrier bearing a thorough inspection.
Old Sep 19, 2010 | 09:46 PM
Clunk's Avatar
Like Katoom sez and be sure they work smoothly the full movement. My '92 front u-joint/rear driveshaft/front half would get stiff before the trans/transfer case yoke made contact with the driveshaft yoke.
Old Sep 21, 2010 | 09:26 PM
maintman's Avatar
I had a simillar prob. with my 99 , turned out to be a broken brake spring on the rear , and the rear brakes would stick momentarily after being applied.
Old Sep 22, 2010 | 06:23 AM
shaft's Avatar
that's a great input. I'll check it out. Thx.
me4osu
Mar 22, 2003 04:03 AM
DarrellB
Dec 21, 2002 05:43 PM
Wade
Nov 20, 2002 12:38 PM
DieselDaze
Nov 3, 2002 08:23 PM
