What is a CKP sensor?
Old Sep 21, 2013 | 12:28 PM
LUKE-MM-PULLER's Avatar
Had the injection pump on my 01 HO replaced and now there is a 1690 code. So What does it mean and how does one go about fixing it?
Old Sep 21, 2013 | 09:57 PM
SIXSLUG's Avatar
IIRC 1690 is a companion code thrown when the ECM/PCM have a misunderstanding. It should go away after a few starts/shut downs...
The dreaded 0216 is the one you don't want to see.
Old Sep 22, 2013 | 07:26 AM
Greg Reed's Avatar
1690 code is Cam Position Sensor. It is located near the VP44. If your VP44 was replaced, maybe they didn't get the harness back on the sensor or maybe the connector is dirty. The sensor is located on the back of the timing cover above the VP44. Do a search for Cam Position Sensor. You should find some photos.
Old Sep 22, 2013 | 09:05 AM
Thanks guys, now I have a place to start!
Shovelhead
May 2, 2009 05:57 PM
Grider Pirate
16
Oct 11, 2007 07:47 AM
Clint
Nov 28, 2004 04:04 PM
daystar
Feb 25, 2004 02:57 PM
Diesel-Dan
Nov 24, 2003 04:22 PM
