water in fuel light
Old Apr 27, 2006 | 10:43 AM
singleturnout's Avatar
water in fuel light
my water in fuel light came on this morning i just flushed out my water seperator a few days ago on my fass any ideas guys i throw a bottle of power service in the tank do you think ill be ok
Old Apr 27, 2006 | 05:22 PM
.....bump.......
Old Apr 28, 2006 | 01:17 AM
Ph4tty's Avatar
Isn't the sensor in the stock FF? Are you still using the stock FF or did you bypass it with the fass?
Old Apr 28, 2006 | 05:27 AM
jrs_dodge_diesel's Avatar
If you still have and use the stock fuel/water seperator system then you might want to clean your WIF sensor.
Here is where the sensor is located on the canister. This is the side that faces the front of the truck.
And this shot shows what the probe looks like on the inside.
Old Apr 28, 2006 | 07:24 AM
i dont have the stock fuel filter assembly i have the fass with the filters i think i might of known what happened the connectors for the stock fuel filter are still there and i washed my truck so i think they might of got wet and tripped the water in fuel light
Old Apr 28, 2006 | 07:45 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Geeeze Louize JR., are you scraping up asphalt and boiling it down for fuel?
My filter canister has never looked like that and I change mine about every 20,000 miles.
You must be getting some real junky fuel over there.
Old Apr 28, 2006 | 12:21 PM
need12v's Avatar
ok here's a question. Can I unplug the WIF and Heater and not set codes in the ECM? I'm also bypassing the stock filter.
Old Apr 28, 2006 | 06:26 PM
I get my fuel from a station that has more diesel traffic than any other station that I've seen. Its a 76 station if that matters. It may not be the cleanest, but I believe it it the freshest fuel than most other stations out here.
I change the filter every 10K and wipe out the canister when I do. Good thing for the Fleetguard Stratapore.
If I knew how to get diesel out of asphalt I might be doing that instead of paying $3.20 a gallon.
Old Apr 28, 2006 | 08:27 PM
phox_mulder's Avatar
Yes, (on the WIF anyway unsure on the Heater),
just make sure you waterproof the connector, vaseline and duct tape work wonders.
phox
stratos201proxl
Jan 16, 2014 11:04 AM
Joey-D
Dec 12, 2011 12:52 PM
DodgerDoob
Oct 1, 2008 07:49 AM
nooska
Jun 19, 2008 08:30 AM
acker1
Jun 30, 2003 03:13 AM
