Warm/Hot starting?
Old Jun 27, 2005 | 08:18 AM
xp8103's Avatar
Question Warm/Hot starting?
Took the truck to MA this weekend hauling a small utility trailer. All highway. Stopped on the way home after about 130 miles of driving at a rest stop. Let her cool down (egt's to around 300 degrees) for a bit then shut down and went inside to eat. Spent about 20 or so minutes, came back out, hopped in, hit the key, WTS light shuts off, crank, fire, die. Huh.... Key on, crank again crank crank crank crank fire, start run. No problem.
Got home, backed into the driveway,cool down, shut down. Come out half an hour later, crank fire stall. Crank crank fire start run. No problem.
Odd behavior????
Old Jun 27, 2005 | 08:26 AM
dezlsmkr's Avatar
Mine does that exact thing when the fuel filter needs to be replaced.
Old Jun 27, 2005 | 08:35 AM
xp8103's Avatar
Hmmmm... Fuel filter was replaced within the last couple thousand miles... Could be gunked up tho....
Old Jun 27, 2005 | 08:48 AM
dezlsmkr's Avatar
Well it may be something esle maybe LP or Ip. I just know that when mine gets bad you crank it and no more than it starts it dies, then crank it again fires right up no problem, but i lose alot of my smoke.
Old Jun 27, 2005 | 09:20 AM
Mopar1973man's Avatar
Check for air in the fuel... You could have a air leak in the system causing the hard starting.
Old Jun 27, 2005 | 09:21 AM
xp8103's Avatar
Haven't run it today. It's home in the driveway. Will check starting when I get home.
Old Jun 30, 2005 | 12:54 PM
xp8103's Avatar
Truck has not failed to start since. Am replacing the LP soon tho.
mtb1982
55
Jan 20, 2020 10:45 AM
klx650a2
Jul 22, 2008 06:47 PM
herb
Jul 18, 2008 08:25 AM
edwinsmith
Apr 14, 2006 03:53 PM
duallydave
Aug 7, 2005 09:38 PM
