vp44 replacement question...
Old Apr 7, 2006 | 11:13 AM
pmtg's Avatar
when pulling the injection pump gear off the VP44 pump shaft, what size are the threads in the gear? i've searched and only found that a certain brand puller comes with the correct bolts but would rather know what the thread size is since i have a machine shop at work that could make me a puller.
i also spoke with a company last night and they said the pump usually slips right off the gear and there is no need to use a puller seems everyone else needs to use one so that comment threw me for a loop, but maybe some truth to it?
any help would be appreciated. thanks!
Old Apr 7, 2006 | 12:14 PM
99 cummins's Avatar
I just used a little cheap steering wheel puller when I did mine. Can't tell you the size but it was just a standard bolt that came with the puller set.
Old Apr 7, 2006 | 01:57 PM
blackdiesel's Avatar
Registered
the bolts that hold on the apps are the right size. You could use them or take one out and size it. IMO you will need a puller. I use a little one we had laying around had to grind a little on it. It was a little wide, but goter done
mopar440cu
Nov 28, 2012 10:33 PM
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
