vp44 pic
Old Jul 13, 2007 | 04:32 PM
stix's Avatar
vp44 pic
I have been having fuel problems---I have removed all aftermarket stuff(comp and timing box) with the exception of piller guages. The truck is now stock but there is this wire coming off the top portion of the vp44---do you know what it is(sorry the pic is bad I will try and get another)--The vp44 seems to have two different connections---is it possible that one of my boxes was attached to this point.Is it possible this is causing my dead pedal problem?? I also bought today a cam sensor from cummins to see if that helps.
I have a 99 2500 LWB Q cab 4x4 6speed
Old Jul 13, 2007 | 04:51 PM
blackdiesel's Avatar
Registered
that's the TAP wire for the comp.I would tape it off. Are you having DP and getting the 0216? If so you will more than likly have to get a new IP to fix it.
Old Jul 13, 2007 | 04:59 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Yeah, that diffinately a fuel box tap wire. And, yes, do you have any codes? Sounds like an IP problem.
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
DMS1707
23
Nov 5, 2008 12:53 PM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
