VP44 Differeces
Old Nov 3, 2006 | 09:07 PM
Terraizer's Avatar
VP44 Differeces
Whats the Difference between the VP44 used on the dodges and the ones used on the mid range truck (Frieghtliner)?
Old Nov 6, 2006 | 09:47 PM
DUNEATIC's Avatar
vp44 pump differences
Hi,I'm a certified diesel mechanic for peterbilt trucks & I just so happen to be certified in B & C ceries Cummins engines. There really is no difference between the pumps externally or internally, they both do the same thing. Where you run into the difference is the horse power rating on the engine. There are #'s stamped on each pump that tell you what date it was built on & you dont want to get any pumps built on or before 12/03 due to having a stainless steel bushing in the rotary pump which would sieze up & cause pump to fail,the pumps built after 01/04 have a bronze bushing and are great pumps. Bottom line is that the pump will work on any engine just beware of the dates on the pumps which if you call your local cummins dealer they will tell you what date pump you have. Hope this helps you out.
2001 SLT Quad cab 2500 4x4 White Short bed 2.5in skyjacker leveling springs,285/75/16 uniroyals,edge juice w/attitude, 4"mbe stainless turbo back exhaust,afe intake,fass red fuel pump
Old Nov 6, 2006 | 09:59 PM
crobtex's Avatar
Very interesting. What about rebuilt VP44's that are bought from vendors others the a Cummins dealer? Will they have the bronze bushing?
Old Nov 6, 2006 | 10:19 PM
DUNEATIC's Avatar
That my friend I cannot tell you I only am familar with the factory & remanufactured pumps from cummins, my thoughts are that they probably would.
Old Nov 6, 2006 | 10:25 PM
Mopar1973man's Avatar
Very interresting information on the VP44 pumps...
Old Nov 7, 2006 | 06:40 AM
crobtex's Avatar
Thanks. You would think that all Bosch rebuilds would have the brass......or would they. More $$$$.
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
raceguy13
Apr 26, 2008 10:11 PM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
