VP44 Culprit??????
Old May 14, 2008 | 10:28 AM
babyjoe's Avatar
VP44 Culprit??????
Well my VP is dead as some know, When I bought this truck 5months ago I hooked up a fuel press. light, and it was instantly on...So I have no clue how long the lift pump was out, So I installed a new lift pump and it has run fine till last Thursday..now dead I have been waiting on my pump, I crawled under the truck to check the tank vent, due to I read it being plugged could cause a VP failure and sure enough it was plugged with dirt.....So question will and did this destroy my pump.....thanks...
Old May 14, 2008 | 11:45 AM
kantdrive55's Avatar
DTR Advertiser
Chances are your pump was basically done before you replaced the lift pump. The problem is they usually run quite a while with very low fuel pressure which hurts them. Then by the time the lift pump is replaced the injection pump is usually not too far behind it. The plugged problem probably added to the failure, but it most likely was the lift pump that did the damage.
Old May 14, 2008 | 12:50 PM
babyjoe's Avatar
Thanks a million man, Kinda cool to talk to somone from BD, that where I got my light kit after I bought the truck...
Old May 14, 2008 | 01:00 PM
DTR Advertiser
Hey no problem, by the way I will be signing autographs at 3 This is a pretty common problem and this is what that light kit was designed for. Think of it as a $65 insurance program against a $2000 pump job.
Old May 14, 2008 | 04:41 PM
babyjoe's Avatar
ah geez, I didn't meen to make your head swell
NO_SPRK
Nov 30, 2009 08:37 PM
Rick 12v CTD
Sep 7, 2009 04:14 PM
Russ Dogg
Sep 17, 2007 11:27 PM
caleb c.
Mar 26, 2007 06:00 PM
marine4life
Apr 6, 2006 01:14 PM
