VP44
Old May 18, 2003 | 10:25 PM
commtrd's Avatar
VP44
Here's an idea:<br><br>Why not retro-fit a 24valve engine with a different fuel pump? Since the vp44 is obviously an inferior pump, why not use a pump from a 12valve engine? This would entail migrating from total computer control of the engine but that may be a good thing. It would almost be the same as putting a CTD into another truck (other than Dodge). <br><br>After all, the different approaches to fueling the engine always were designed around improving emissions, NOT improving fuel mileage and performance!
Old May 18, 2003 | 10:27 PM
Stamey's Avatar
Re:VP44
I just wonder if it would bolt in there. I've never examined either one closely but someone on here probably has experience with both.<br><br>Chris
Old May 18, 2003 | 10:32 PM
drecu's Avatar
Re:VP44
Someone has done a P-Pump Conversion i'm not sure who right now but I have seen pic's of it takes a lot of money &amp; work but it's an awesome setup!<br><br>DRecu!
Old May 18, 2003 | 11:33 PM
BigBlue's Avatar
Re:VP44
Jetpilot just did one on his truck. He was running 12.1's with his VP44 so I wouldn't call that inferior. I think he's one of the fastest Cummins in the country. The P-pump conversion is VERY involved and VERY costly.
Old May 19, 2003 | 05:24 PM
commtrd's Avatar
Re:VP44
I must admit that the vp44 on my truck never gave me any problems. I did get a rude awakening when I took the truck to the dealer to get a bad oil sending unit replaced (under warranty) and they spotted my van aiken box and informed me that my drivetrain warranty from that point on was null and void. Also they said a new fuel pump was $3000! I was not aware at the time I bought the fueling box that it would void the warranty. That's the same time I started reading these Ram truck forums on TDR and DTR.com to find out what else I didn't know about my truck! Anyway that is what prompted me to think of a way around the lift pump/vp44 issues. It is good to be able to listen to other's viewpoints on a topic because there are a lot of very knowledgeable people on this board. I can spend hours reading about Dodge/CTD's!
Old May 19, 2003 | 07:20 PM
HeberRam's Avatar
Re:VP44
Commtrd..In order for you to make a p-pump conversion from a 12v to a 24v you have to change the cam. Since the 12v p-pump is mechanical, you have to put in the cam that has a lobe on it to drive the pump. The 24v cam doesn't have that lobe and the hole where the p-pump would be mounted has been capped off. In addition, the electronics have to be modified, ie. ECM, Map sensor, IAT sensor, as the ECM uses this information for fueling and timming. The 12v p-pump has the ability to flow more fuel then the present VP-44 and is easier to modify. That's why, some have gone through the expense of conversion to push more fuel and run large injectors. Most truck pullers and drag racers use 12v trucks because of that reason. I and a hand full of others have a Diesel Dynamics modified VP-44 which is the only company to successfully modify the VP-44 for more fueling. Approx. 60-70hp. Both Piers and Diesel Dynamics performance cams have the lobes on them for future p-pump conversion.<br><br>Steve
mopar440cu
Nov 28, 2012 10:33 PM
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
