Vp44
Old May 16, 2007 | 11:41 AM
RJW922's Avatar
Vp44
I am having a LP replaced as I post this, mechanic says the IP has been damaged. Says it could take a dump tomarrow or go on along time.
If it goes,( or when) what are my options for replacement?
2001 2500 4x4 QC , Jardine 4"exhaust, 100% synthetic, 105K miles
Old May 16, 2007 | 12:09 PM
csutton7's Avatar
did it throw a code--if it didn't then why change the IP pump---now with that being said your VP will fail and it could be tomorrow or it could be in a couple of years or longer---but if it threw a code then I'd think about changing it now---for pumps you can get stock ones, Hot rod pumps(HRVP) or the new monster pumps(hard to get in a timely fashion though unless you're lucky)---or you could P-pump it----but since your truck looks mostly stock I'd look at a stock replacement---but tell us if there's a code that's been thrown----chris
Old May 16, 2007 | 12:17 PM
RJW922's Avatar
Check engine never came on, but codes 1693 and 0216 show up.
Having stock pump put on for now.
Old May 16, 2007 | 12:36 PM
csutton7's Avatar
0216 means problems with the VP44 or the IP--probably smart to change it--
1693 is a generic code for lot's of things---always minor things, but it shows up a lot when almost all other codes are thrown--
chris
Old May 16, 2007 | 12:37 PM
csutton7's Avatar
VP44 and IP are the same thing---just in case you wondered...chris
Old May 22, 2007 | 03:43 AM
EverydayDiesel's Avatar
im new to diesels what does VP44 mean?
what does IP (intank pump?)
ive searched and found talk about the p-pump but what is that? (power steering pump)?
any pics are greatly appreciated if anyone has any.
Old May 22, 2007 | 06:57 AM
blackdiesel's Avatar
Registered
vp44 = IP = injection pump = 1k + labor. p-pump is a IP for a 12v. LP = lift pump some times it's in the tank (retro fit)
Old May 22, 2007 | 09:56 AM
csutton7's Avatar
on 12valve trucks they have a mechanical lift pump--basically like an old chevy fuel pump that was actuated by a rod --this lift pump(or transfer pump) transfers fuel from the fuel tank to the high pressure pump called a P-pump--the P-pump then pressurizes(high pressure) the fuel and sends it to the injectors...
a 24 valve truck has an electric lift/transfer pump that transfers fuel fromt the tank to the VP44(IP) which then pressurzes(high) the fuel and sends it to the injectors---
the intank lift pump is an attempt by Dodge to deal with their stupid location of the lift pump---I suggest you never do this even if the dealer says it's a good thing to do--
chris
Old May 22, 2007 | 10:49 AM
im in the market for a truck..should i favor a 12v or 24 valve?
Old May 22, 2007 | 01:46 PM
Dr. Evil's Avatar
12V....the 24V's do have fuel system issues that can be fixed if you dont mind spending the $$.
The most desirable 12v's are 96-98's with manual tranny. Its getting hard to find one that isnt abused and most are starting to get serious miles on them.
mopar440cu
Nov 28, 2012 10:33 PM
DieselRebel24
Dec 4, 2010 03:22 PM
Erska
17
Mar 6, 2009 09:52 PM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
