VP to CR 5.9 block differences?
Old Mar 26, 2010 | 03:12 PM
Moose10's Avatar
Guys, can anybody tell me if there are any differences between an '03/'04 CR block and my '01 ?
I'm looking to buy a complete bottom end and put my '01 head on it. Will it work? Is the cam the same?
Thanks for any info?
Old Mar 26, 2010 | 04:26 PM
Tate's Avatar
Blocks are different, timing case won't bolt up to the CR block. Cam's are different. CR's use straight cut gears, the rest use helical gears.
Old Mar 26, 2010 | 07:18 PM
Moose10's Avatar
Thanks for the input Tate, but I found a complete motor minus the CR head so I would'nt have to use my current timing case. Do you know if I'd be able to use the VP and just put a straight cut gear on it?
I really hate to pass this up...it's an '03 motor with 12k miles for $800
Any way to make it work?
Old Mar 26, 2010 | 07:21 PM
Moose10's Avatar
For a little background, this is why I'd like to get the '03 motor...
https://www.dieseltruckresource.com/....html?t=263588
Then I can take the time and really go through my knocking motor...
Old Mar 26, 2010 | 11:20 PM
Tate's Avatar
Timing case is what the VP bolts to and contains the gears. You need to use the VP case to use a VP pump. CR case is completely different and won't allow a VP at all. Unless you drill and tap the block to accept the old style timing cases, you're SOL.
Old Mar 29, 2010 | 11:01 AM
bludodge21111's Avatar
Cant u do a CP3 conversion?
Old Mar 29, 2010 | 02:42 PM
Tate's Avatar
Would be much easier to just find a complete CR to swap in instead of converting a VP to CR.
Old Mar 30, 2010 | 10:06 AM
No im not talking about converting a 24 valve to a CP3 im sayin why cant u use the whole common rail motor instead of putting the VP on the new motor?
Old Mar 30, 2010 | 04:27 PM
Moose10's Avatar
Well the guy has the whole motor that he's willing to sell too, but I don't know jack about how the whole wiring / ECU thing would work......suggestions??
Old Apr 14, 2010 | 03:28 PM
Moose10's Avatar
ttt,
SO who's got the smarts on putting a CR engine in a 2001 truck...computer and all?
Old Apr 14, 2010 | 05:37 PM
nickg's Avatar
I believe you can get a harness from Painless wiring, that will allow you to stuff the CR engine in there, I think the last time I looked it was around 1000$ expensive but it would eliminate alot of wiring headaches
txrammer97
14
Nov 16, 2008 08:53 AM
Bubspc
Jul 27, 2007 10:32 PM
24Vford
Jan 2, 2007 11:14 AM
plow
Dec 28, 2005 02:42 PM
1320
May 17, 2003 03:28 PM
