vp/44 or not
Old Jun 26, 2006 | 08:56 PM
RobD's Avatar
vp/44 or not
Ok My Truck Is A1999 24v Ctd.i Was Having Hard Starts With It After Driving It And Letting It Set For Awhile.if I Let It Set For Several Hours It Would Start.no Signs Of Anything Wrong While Driving It. Started To Get Harder To Start After Doing This For A While.maybe A Week Or Week & Half.so I Started By Replacing L/p With The Intank Pump (mopar).still Doing Same Thing So I Then Replaced Fuel Filter.(i Realize That I Should Have Started With Fuel Filter And Then Change Pump).truck Is Now Working Fine No Hard Starts. I Went Ahead And Ordered A New Vp/44 Before Changing F/f Thinking That Was The Problem.should I Return It Or Replace It.i Am Not Sure If There Is A Way To Test My I/p That Is Currently In My Truck.thanks For Any Help.you Guys Sure Know Your Stuff.
Robert
Old Jun 27, 2006 | 09:23 AM
Olratlr's Avatar
vp/44 or not
I don't see any thing listed on your truck profile as if you have a fuel pressure
gauge are not. I would start with a gauge and that would determined if you
should keep VP44 are not.
Old Jun 27, 2006 | 06:19 PM
Sixpack's Avatar
Check for codes. You'll need a code reader. Hopefully you won't find the dreaded P0216 code.
Diesel-Dan
20
Sep 22, 2019 09:34 PM
04ctd
Mar 8, 2006 11:22 AM
Scotty
Sep 11, 2005 12:37 AM
NHDiesel
Sep 2, 2005 11:23 AM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
