vp 44 failure?
Old Nov 25, 2011 | 02:10 PM
maulmaniac's Avatar
vp 44 failure?
stock 99 24v.
unknown history 260k miles.
Truck wont start. Good fuel pressure, no codes. When I crack the injector lines with the key on and fuel pump running, fuel comes out under low pressure without engine cranking. Does this sound like the vp44 o-rings or diaphram leakage?
Crank sensor?
Maulmaniac
Old Nov 25, 2011 | 06:31 PM
SIXSLUG's Avatar
Could be, or a bad/worn seal in the vp that leaks fuel by.
Check out Bluechip diesel's page for a ton of info on this symptom.
Old Nov 26, 2011 | 11:57 AM
maulmaniac's Avatar
update
Engine wont start and Check engine light came on and a code of 1689 and 1693 codes showed up.
Dead vp44?
Maulmaiac
Old Nov 26, 2011 | 04:49 PM
johnh's Avatar
Dead vp44?
Maulmaiac
yep! injection pump control module is gone
IPDiesel
Jul 29, 2015 09:57 PM
dodgetrucker75
Mar 17, 2011 09:15 PM
quantrill88
Mar 19, 2003 05:04 PM
Map70
Mar 18, 2003 08:19 AM
Rigg4x4
Nov 23, 2002 06:42 PM
