VP-44 acquisition
VP-44 acquisition
Hello everyone! There is a fellow selling a brand new "still in the bag" remanufactured VP-44 online for $750 which will fit all diesels other than the 2003-2004. I'm wondering if it is something that should be "snatched up" just in case one is needed in the future? Being that they're $1250 from a dealer, it sounds like a good deal. After all, I am always hearing that these units are constantly going bad. Any input? Thanks .....Myles
Here's the information which was supplied. To your knowledge, will this work on a 2002 24 valve diesel 5.9 motor? Thank you....Myles
"Bosch VP44 fuel pump for the Cummins ISB engine. Brand new reman pump is still in box, and in sealed plastic still. Part #3937671-RX"
You will most likely want to make sure that the pump matches the engine (some people dont, but that is a different story).
Like Jerry asked: is the pump off of an ETC (standard output SO), or an ETH (high output HO)? Also, which one is the 2002 that you mention?
It is a great price if it is truely a "new" reman.
Matt
Matt
your engine has a CPL number on the same tag that your Serial number is on , it is a control part list number , if you give me your serial number I can look it up and tell you what your CPL is .
john for grins my engine is 56430100 i think that is ser# was in palmie. if piano d dosnt get it i may be interested. engine family# is wcexho359bag if that means any thing
John i just talked to kenworth/cummins here in denver and then talked to cummins
in denver and they both gave me part# 3937671RX
who is right or will both part#s work yours and theirs?
My cpl # is 2024
My cpl # is 2024
Well...I'd be a bit cautious. We do know that the VP-44 has "evolved". Bosch is finally somewhat comfortable that the latest editions are the best it will evolve to. If this is a recent rebuild, then it sounds like quite a good price. If it's an older rebuild, then all bets are off.
Does the P/N identify it' revision level?
I will check on this , there are a set of pump numbers that are usable for field fix and that is not one of them , gotta remember there are 21 different keys that can be used on the pump shafts for different timing and each key will also have a arrow on the key that can not be installed the opposite way it came . let me check on those numbers
Mr Piano
Thought you mentioned , on another thread, your truck/pumps were still under warranty? Why think about buying a spare?
2002 Fuel Pumps are not "constantly going bad". It's usually only when a lift pump fails and goes unnoticed, over stressing the FP.
I know you had that problem but it's Dodges problem...No?
RJ
RJ
